Old 07-08-2002, 10:34 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
Upgrade to Cold Air Intake?
OK, I have an APC Short Ram intake with K&N Filter. I also have DC Creamic Headers, Catco HF Cat, and DC Catback. Would I be better off upgrading to a CAI? Now much of a differance will it really make? Anything noticable? Thanks!
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 07-08-2002, 10:50 PM
JasonAccord98LX's Avatar
JasonAccord98LX JasonAccord98LX is offline
Send a message via AIM to JasonAccord98LX
Yes you should upgrade to a CAI. Some short-rams can actually hurt performace because they are actually sucking hot air from the engine compartment into your engine. They simply arent long enough to get away from the heat given off by your motor and manifold. Of course, this all depends on how your engine bay is set up. You will notice a difference, but dont expect anything drastic.
-Original PH Member-
Registered in May of 2001
'98 Honda Accord Sedan 2.3L VTEC 4cyl 5-speed
Generic Cold Air Intake
205/60/15 Bridgestone Potenza RE950's
Save the Oompa-Loompas.....a site I helped create
http://www.oompa-loompas.net
Old 07-09-2002, 10:11 PM
Rgacke's Avatar
Rgacke Rgacke is offline
Agreed. Especially in older accords, exhaust is to close to filter.
"shut the door Joshua, and let death pass by..."
Old 07-09-2002, 11:07 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
during some RPM, short ram intake gain more power than CAI. personally..i would go CAI though..
Old 07-10-2002, 08:57 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
does anyone know where i can get just the lower half of the cold air intake system, i dont wanna have to buy a whole new piece.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-10-2002, 10:05 PM
thewoahna's Avatar
I know that DC Sports sells somthing like that
AOL IM: WoahNa316
Old 07-12-2002, 02:33 PM
ViGGa2LO ViGGa2LO is offline
Send a message via AIM to ViGGa2LO
short ram is worthless, sorry i had to be the ne to tell you this but after your rngine gets warm the short ram does as much good as a cone filter on a stock hose.... the cold air is much better to go, and i have even heard people saying that the stock box with k&n filter is better than cold air... but i dont know, just saying short ram =waste of money
Old 07-12-2002, 09:38 PM
Rgacke's Avatar
according to me, the most efficient way to get cold air to a hot air intake is not to spend big bux on a fancy name brand 90 degree bend. thats all it is, a piece of pipe that is bent, so you can either buy a mandrel bend and clean it up and paint/polish it or you can go ghetto style like me. I used 2 straight/adjustable air ducts from home depot. There these tin pipes with angled section so you can twist different parts to shape it how you want it, 1.50 a piece. I then used heat reflective/bendable dryer duct and put that over my entire intake as a heat shield. I was bored and those three parts didn't cost 10.00.
****remember to re-set your ECU******
Old 07-12-2002, 10:38 PM
crxlvr's Avatar
yeah but a custom intake wont have those bend marks in them which slows air travel into ur engine.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-17-2002, 10:08 PM
Silvia2NR Silvia2NR is offline
Send a message via AIM to Silvia2NR
i heard that if you get a CAI and add the air-bypass valve that you will end up with the same performance as a short ram.
what do you guys think?
Old 07-18-2002, 05:43 PM
NuEra's Avatar
NuEra NuEra is offline
Banned
the air temp difference from the engine bay where the short ram is and the wheel well for the CAI is amazing on a car with a hot engine. CAI is soo much better.
Old 07-20-2002, 01:55 AM
so-cali so-cali is offline
In response to Silvia2NR...
"i heard that if you get a CAI and add the air-bypass valve that you will end up with the same performance as a short ram."
This is only half true. The bypass valve is not engaged the whole time. Only when the intake begins to suck water up the tube is when it begins working. If your not driving with your filter taking on water, the bypass valve will act just as another part of the pipe leading to the intake and there will not be a loss in power because the cooler air is still being drawn from down by the wheel well and out of the hot engine bay.
Once water begins to be pulled up the tube, the bypass valve will activate and the suction of the water by the intake causes the tube to be closed off so that it cannot take water into the engine. At this point, the air is drawn from within the engine bay. It will continue pulling air from here until the water goes back down and out of the tube. After the water is gone, the suction on the bypass valve will cease and it will go back to pulling air from the filter down by the wheel.
The performance of a CAI with a bypass valve only drops down to that of a short ram when the intake begins pulling up water because the bypass valve will be pulling air from relatively the same place as the short ram filter would be located.
So basically, you wont see a decrease in performance from your CAI after adding a bypass valve unless u drive through a big puddle. If you live in a place that takes on a lot of water and you crave maximum power while driving through deep puddles, then i could see your concern for performance.
And also in response to NuEra, i believe that you will see a 1% hp increase for every 11 degrees cooler the air is that goes into the engine.
1991 Acura Integra
Pioneer DEH-3400 Head Unit
Eclipse 82641 Speakers
4-ch 1000 watt Sony Amp
2 12" MTX 5000 subs/Bandpass Box
