Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-26-2006, 02:17 PM
comingofage03 comingofage03 is offline
83' Chevy Caprice- Starting Help!
Why would I have to pump the gas to get the car started in the morning. I adjusted the choke.. cleaned the carburetor ... and changed the fuel filter. The car runs fine and starts up without a problem once the engine has warmed up. But when I go to crank it up in the morning... It won't start unless I pump the gas. What could this be? Thanks for the help. 5.0, 305
Old 03-26-2006, 02:52 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 83' Chevy Caprice- Starting Help!
Choke adjustment if it won't stay running until you gun it a few times -
Carbureted cars don't start right up after sitting overnight (and getting overnight cold). The gasoline in the carburetor passages, as well as in the intake (vapor), tend to dissipate after a few hours. It's easy to forget this in today's world of electronic fuel injection. A good tuneup involving new plugs, cap, wires, rotor and all filters will help with cold starts, but you will never have it fire instantly after overnight sitting with a carb.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-26-2006, 03:12 PM
Well I figured that by pumping so much gas into the carb... that I could possibly run the risk of damageing something else. But thank you so much for that answer.
Old 03-26-2006, 04:50 PM
TommySS TommySS is offline
The fuel bowl is emptying overnight/extended periods. You have to pump it, then crank, pump some more, then crank.
The rest of your starts should be fine.
Old 03-27-2006, 03:12 PM
GreyGoose006 GreyGoose006 is offline
You should have to pump the gas twice to get the car to start. this refills the carb w/ gas, and engages the choke. you probly wont flood it unless you pump a lot, like 10 or more times before cranking.
Old 03-27-2006, 03:36 PM
silicon212's Avatar
Confoundingly Lucid
It doesn't refill the carb, only the fuel pump can do that - what it DOES do is spray liquid gasoline from the bowl - through the accelerator pump - along with some vapors into the intake, which should be sufficient to start the engine.
Old 03-27-2006, 03:43 PM
alright lets not get all "YOU SUCK", just trying to help out.
