Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 03-26-2006, 01:26 PM
99avenger2.5 99avenger2.5 is offline
shake when accelerating
I just bought a 99 avenger with 2.5l. The vehicle shakes when I accelerate. The shake is more noticeable when starting off from a stop. I thought it might be the tires since they were wearing unevenly. I replaced the tires and had the car aligned. The problem did not go away. I Also inspected the front end for any loose suspention parts and found nothing. Any ideas
Old 03-28-2006, 02:14 AM
Burnerdominator Burnerdominator is offline
Send a message via MSN to Burnerdominator
Re: shake when accelerating
did you check your wheels to see if they were bent?
1997 Dodge Dakota Sport
1995 Dodge Avenger
1980 Corolla Sr-5 (hornet creature)
Old 03-28-2006, 12:51 PM
when I was balancing the wheels they did not look bent. I also rotated the tires to make sure that is was not a wheel problem.
Old 03-28-2006, 08:29 PM
send this guy a privy TheStang00 he knows avengers well he helped me with a few of my probs
1995 Dodge Avenger
Old 03-28-2006, 09:40 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
it sounds like an alignment issue or a tire balance issue but it obviously isnt since youve checked those.
there is a recall on the lower ball joint in the front control arms. check that. just take it to a dealer and have them inspect it, if its not right they will replace it for free.
Old 03-29-2006, 11:12 AM
neon_rt's Avatar
neon_rt neon_rt is offline
It sounds like a CV joint problem. With a bad CV joint, you will feel a pulsing when you turn sharp while moving slow, this pulsing will feel more like a vibration when you are moving faster. The harder you accelerate the harder the pulsing will be. Basically the more stress you put on the joint by turning and/or accelerating the more pulsing you will feel. If this is the case, you will need to have the CV joint fixed soon. The high speed vibration will destroy the transmission seal were the axle connects to the trans. If the joint decides to break, you will be stranded. These usually fail b/c the rubber boot that protects the joint gets a hole in it and all of the grease leaks out or in case of having a automatic transmission, the driver has a habit of putting the car in Park without applying the E-brake. After you put the Trans in park and then take your foot off of the brake you may notice that many times the car will roll forward or back 2-3 inches. B/C the trans is locked, there is no cushion for the impact on the CVs. Repeated slamming of the weight of the car against the CVs when the trans is locked will cause them to wear out faster than they normally would.
Old 03-30-2006, 09:35 PM
i thought that it might be the cv joints, but I was not sure how to check them. how do you check them and if it is them are they easy to replace
Old 07-02-2006, 04:59 PM
Ramvenger Ramvenger is offline
Send a message via AIM to Ramvenger
I read somewhere that it was because of the transmission... something to do with the TC or something. I'm not sure but it said that it would shudder from a stop.
