Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-26-2006, 12:50 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
2.3 or 2.4?
Well it sounds like I'm taking high performance enging building this summer and I want to build a new motor for the talon but I cant decide what I want to do. I know for sure I want to go with bigger displacement but I cant decide between a 2.3 storker or a 4g64 bottom end, any input on which would be a better way to go? Either way I want to have everything forged and basically a bullet proof motor. I'll be doing ALL of the work myslef, including machiening so which way would be cheaper in parts and or which would hold up better?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-26-2006, 01:07 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: 2.3 or 2.4?
Old 03-26-2006, 01:10 PM
Black99GST's Avatar
Re: 2.3 or 2.4?
WEll... The 2.3 has a longer RPM range, which is what turbos like... But then again, the 2.4 will have more displacement... which turbos like... so as i said before...
Originally Posted by Black99GST
Old 03-26-2006, 08:36 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 2.3 or 2.4?
I'd go 2.3 stroker. The 4g64 takes a bit of customization to get into the engine bay and the 4g63 head on top right? I dont think the .1 L of displacement is worth it.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-26-2006, 08:39 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Re: 2.3 or 2.4?
I would go with the 2.3 liter if it Revs a thousand or more higher than the 2.4. The higher you can rev the less shifting you need to do.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 03-26-2006, 08:53 PM
blk_srt's Avatar
Re: 2.3 or 2.4?
Thanks for all the feed back guys. I think I'll be going with a 2.3
Mods:
Old 03-27-2006, 01:27 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 2.3 or 2.4?
Revs wont be different, the crank and rods are the same Unless you do a longrod 2.4. In the end they are really the same thing. The stroke is the same, and the bore can be the same (2.0 block at 060 over). A 2.4 is really on a 2.35 rounded up as well. Same thing IMO. Only real reason I see for going through the trouble of getting the 2.4 block in is the long rod option...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-27-2006, 01:42 AM
95_GSX's Avatar
Re: 2.3 or 2.4?
I didn't know that, I guess it would be better to get the 2.4 block. Im not trying to hijack this thread but: Kevin what are your thoughts on the 2.1 destroker?
Got AWD?
'08 Buell 1125R
Old 03-27-2006, 08:26 AM
AF - Advisor
Re: 2.3 or 2.4?
I think the 2.1 is a great idea for a drag race car, as long as you can get a tranny that shifts at high rpm to take advantage of it's ability to rev. It would also make the same power with less torque, so the drivetrain should be a little happier than with a full stroker. You still get 5% more displacement/airflow, which is nice. Not a bad option. But again, if you are going to go through the trouble of installing the 2.4 block, you might as well do the long rod 2.4 which will still rev much better than a regular 2.3 and get 20% more displacement and airflow. Then shifting is less of an issue, but keep the drivetrain together might be. As usual with these things, it's a tradeoff and you have to chose based on the overall theme of the setup.
Kevin Jewer
