Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-08-2002, 09:55 PM
SuPrBuGmAn SuPrBuGmAn is offline
Stock 95 GST boost?
How much boost can you get away with running on a stock GST(have access to an upgraded computer for a 20g turbo PIP, head, and larger fuel injectors)?
For a friend, he thanks you in advance. :bandit:
Old 07-08-2002, 11:27 PM
ECTurboGSX ECTurboGSX is offline
Send a message via AIM to ECTurboGSX
Boost is not relevent, CFMs are (Cubic Feet per Minute). For example, 25 psi on a 14b is no where near 15 psi on a mutt level 3, or else no one would buy a new turbo. For the 20G, and I am assuming your question is how much the stock engine can handle, you can probably get over 20 psi on the stock internals with the right tuning. I'm not sure on the flow ratings for the 20G, but a stock 4G63 can handle around 450 horsepower.
Eric
1990 Mitsu Eclipse GSX
13.4 @ 102.9
Big 16G @ 19 psi
Old 07-15-2002, 02:04 PM
aves911's Avatar
aves911 aves911 is offline
Massive Genius
Send a message via AIM to aves911
As long as you have the proper electronics to control your injectors (I recommend the Apex-i S-AFC) and you either monitor your O2 voltage or better yet your EGT's you can run as much boost as your car can handle. The stock MAS on the 2G can only meter airflow to support 400 horsepower; anything over that and you'll have to go with the HKS VPC. But in your case you should be fine, the 20g turbo hits the top of its efficiency range just shy of 400 horse and can be pushed a dab further. Again, since every motor is different only careful tuning will tell you the max safe boost you can run.
(On the stock T-25 with the stock 450cc injectors don't go over 16psi, you can spike it a little at lower rpms [around 3000-3500] but anything higher than that is asking for a detonated piston)
"this is a funnie thread..
we have a poser who keeps posting information that doesn't fit together..
and aves911 keeps correcting him"
Old 07-19-2002, 12:11 PM
91HBSi 91HBSi is offline
Send a message via ICQ to 91HBSi Send a message via AIM to 91HBSi Send a message via Yahoo to 91HBSi
Re: Stock 95 GST boost?
Is Josh finally going to do something to his car? It's about time, lol.
Lexus SC300 (Kazera KZa 18"x8.5" 245/40 (front), 18"x9.5" 275/35 (rear)... put on hold.
Civic Hatchback Si (I/H/E, d16z6 head, H&R springs/tokico blues, etc.)
94 Prelude Si (Sold!)
Former PureHonda.com member since Dec. 00
"For to me, to live is Christ and to die is gain." Pilippians ONe21
Old 08-05-2002, 03:25 PM
Yeah, he made a manual boost controller
Old 08-06-2002, 10:42 AM
jdoug jdoug is offline
Send a message via Yahoo to jdoug
This is probably obvious, but don't forget that you'll have to get an aftermarket BOV to handle the higher boost, since the crappy stocker leaks anything over about 12 PSI.
J Doug
2003 Mustang Mach 1
1998 Mitsubishi Eclipse GS-T *sold*
Old 08-07-2002, 07:45 AM
Yep, my bud knew about that problem already, but thanks for the heads up. Somethin about the spring inside the stock BOV being way too soft. Anywho, aftermarket BOV on the way for him.
Old 08-07-2002, 10:42 AM
Yeah I saw him the other night. He didn't say anything about a manual boost controller though. Did he make one like the guy at the SCCA? I haven't even ridden in his car yet, I bet it rides really nice now that he got the sus.
Old 08-08-2002, 07:57 AM
He tried making one like on the RX7, but apparently placement and operation are different than the manual boost controller he was supposed to make for his Eclipse. We cranked the RX7 style rigged controller up and cranked it all the way up and all the way down little by little and not a damned thing ever happened Wasted 90min of my life for nothing! bwhahaha! He ended up finding blueprints on the net for a manual boost controller for his Eclipse. Supposedly it works, he just needs a new BOV to handle the boost. His car rides pretty nice, its damned low too--I think its time for some rims though
Me and Matt and the Joshes and everyone are gonna pool up some $$ to get a racing helmet for the SCCA races, wanna put in? We're gonna buy a nice helmet and we'll ghetto it out with ricey stickers from all our brands of cars--then, of course, we will pimp the ghetto.<--note period
You guys still going to Hot Import Nights?
Old 08-08-2002, 08:53 AM
Heck no, because Travis's brother bailed out on us and he is the only way we can get Hotel res. sux being 18. I plan on going to the next SCCA, I won't have a job so I am sure I won't be working that Sunday.
Old 08-09-2002, 08:03 AM
3 Cheers for no job!
Anywho, if you want a job at Stone Int lemme know. We'll be at the races as well. The GTI parts are in---Yeah baby! Yeah! Just need to get body work and paint done to it now.... :smoka:
