Old 03-26-2006, 11:58 AM
tomogchi tomogchi is offline
Send a message via AIM to tomogchi Send a message via MSN to tomogchi
94 civic dx
1.5 liter, 4 speed auto.
Is there anything i need to remove in order to set the timing?
I've got a sh*t load of "pinging" on any acceleration, so im going to check to see wether the timing belt is streched, or if the timings off. It dont matter what octane either, it still happens. lol.
Any tricks to try on this car for timing?
Thanks
Bill
Old 03-26-2006, 10:01 PM
Bruce Hunt Bruce Hunt is offline
Re: 94 civic dx
Do you know where the clip connection for the ECU is to jumper? It should be up under the dash on the passenger side. Find the connector and jumper it. The stops the computer from making any corrections to the timing and you can then check the timing.
If I was able to help you, that made my day; if you offered assistance to me, I thank you so very much! Either way, have a great day! Now own 4 Accords and 2 Civics. Love Honda!
Old 03-27-2006, 12:47 AM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Re: 94 civic dx
Small timing adjustments can also be made at the distributor cap by physically adjusting the position. To do that you can loosen the bolts just enough to rotate the distributor and then adjust until the timing is right. This can be done while the engine is on. I would suggest having a second person to help.
AF COMMUNITY GUIDELINES
Old 03-27-2006, 10:30 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: 94 civic dx
in order for that to work you need to jump the service connector... otherwise the ECU will try and adjust the timing itself... its a 2 prong female clip near the ECU but under the dash. i made a jumper be using speaker wire...
