Old 03-26-2006, 11:24 AM
mwootan mwootan is offline
1996 pontiac sunfire overheating 2.2L
I have a 96 pontiac sunfire overheating continuously. I have replace the thermostat, waterpump, and radiator, even a second thermostat cooler temp and still overheats. I have also replaced temp switch and confirmed the fan is working. Need help bad. What am I missing?
Old 03-31-2006, 02:48 AM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
Re: 1996 pontiac sunfire overheating 2.2L
try doing a compression test, you may have a blown head gasket or a the head could be cracked
1993 HONDA CIVIC EX
BLITZ FRNT M3 SIDE BLACK WIDOW REAR
JSP TERMINATOR WING
17' MOTEGI SUPER SILVER RIMS
D16Z SOHC 1.6 VTEC
SKUNK2 INTAKE MANIFOLD
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
T25 CUSTOM TURBO KIT @ 7PSI
TUBULAR MANIFOLD
AIR TO AIR INTERCOOLER
ALCOHOL INJECTION
18002 TURBO MILES AT 218002 MILES GOING 140MPH FINALLY WENT
BUT, STILL GOT ME HOME
Old 03-31-2006, 06:57 PM
I was wondering though. If you have a cracked head or blown head gasket would'nt you see smoke out the tail pipe or the oil turning to a milkshake color? This engine runs pretty smooth and has good power but this just does not make sense. Thanks for responding, Mike.
Old 04-02-2006, 08:25 AM
blitzcivic's Avatar
not really your head could be warped and the coolant can be leaking on the side of the head not mixing with you oil and not going into your exhaust. it is a common problem w/ the 2.2l to leak in the frnt driver side of the head.for a peace of mind do a pressure test and a compression test.
1993 HONDA CIVIC EX
JSP TERMINATOR WING
D16Z SOHC 1.6 VTEC
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
TUBULAR MANIFOLD
ALCOHOL INJECTION
