Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 03-26-2006, 08:52 AM
fahnstock fahnstock is offline
2005 Honda Odyssey Keyless Remote Programming
Hi...
Can anyone help me program the remote for the 2005 Honda Odyssey??
Thanks!
Old 03-26-2006, 09:05 AM
lorunner lorunner is offline
Re: 2005 Honda Odyssey Keyless Remote Programming
The codes of up to three transmitters can be stored into the keyless receiver unit memory. (If a fourth code is stored, the code that was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the tailgate are closed.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit built into the power window master switch.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit built into the power window master switch.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 1 to 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit built into the power window master switch.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit built into the power window master switch.
12. Confirm you can hear the sound of the door lock actuators within 1 to 4 sec., then push the transmitter lock or unlock button again, or the code will not be stored.
13. Within 10 sec., aim the transmitters (up to two additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons.
14. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
15. Turn the ignition switch OFF, and remove the key.
Confirm proper operation with the transmitters.
NOTE: Once the programming mode is entered, the remote button must be pressed a second time. If the button is not pressed, or if the ignition switch is turned OFF, the programming for all remotes will be cancelled.
Stop asking me about radio codes I cant get them anymore!!!
