Old 03-26-2006, 08:44 AM
gserve gserve is offline
common problems 2000 blazer
Have a 2000 Blazer LT 4 wheel drive 53000 miles. How common are ball joints(lower) needing replacement and lower intake leaking coolant and transmission cooler lines leaking? Just went for inspection sticker and these items were diagnosed as needing replacement. Note there were no symptoms of these problems.
Old 03-26-2006, 04:10 PM
DINO55's Avatar
DINO55 DINO55 is offline
Re: common problems 2000 blazer
These are pretty common problems with all second generation Blazers
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 03-26-2006, 05:57 PM
TheBrettster TheBrettster is offline
AF Premium User
Yup just took mine in for the same exact things, plus i had to replace a fuel injector.
2001 Chevrolet Blazer LT 4x4
71k Miles,
Old 03-26-2006, 09:22 PM
blazer_guy86's Avatar
blazer_guy86 blazer_guy86 is offline
Intake gasket should be good for a while. Mine just went out on me at 181k miles. Oil cooler lines usually go bad before transmission lines do for some reason.
Old 03-28-2006, 11:09 AM
Phillip Cross Phillip Cross is offline
yup. I replaced all that (oil cooler hoses instead of tranny cooler line) and wheel bearing hub assemblies around 60k.
Old 03-28-2006, 06:05 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
And don't forget about the notorious Ignition Switch, the Pinon seal, or the Radiator.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
