Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 03-26-2006, 08:14 AM
mackace23 mackace23 is offline
95 accent horn
The horn is not working on my 95 accent. Just wondering how I can get at it to check or replace it? I know it is located under the drivers turn signal. Is there a diagram that I can use? Also, the relay is working so I know it's not that as well. Has anyone else had to replace their horn?
Thanks
Old 04-07-2006, 08:46 AM
{LK} Mario {LK} Mario is offline
Re: 95 accent horn
Yeah i have a 95 as well and i was in the same boat you are now. the horn is pretty easy to get to. As you already said, it is located under your drivers side turn signal. The easiest way to go about it is to take out your wheel well liner, and you should be able to get to it from there. Hope this helps.
{LK} Mario
