My car design site.
Hey everyone! This is a site that my cousin and i made , and have been working on for about a week now. Come check it out, and look at our drawings. ( See sig for site. )
PS:My drawings are under "Gabe's designs" |
Re: My car design site.
nice start on designing ( i just started drawing). If you wanna go one step further on this you can read an article or two on aerodynamics or something and may i suggest engine specs or your concepts and music on your site?
^ I was looking at putting on some music soon, and i do have the "stats" page for my cars. thanks for the comments.
Nice site. Keep up the good work and good luck!
^ Thanks a lot.
nah dude i mean specs not the cars direct performance like for example this
2006 Lamborghini Hamann Gallardo Year 2006 Make Lamborghini Model Gallardo Tuner Hamann Engine Location Mid Drive Type AWD Body Material Aluminum with Thermoplastic hang-on parts Price $174,800.00 Weight 3150 lbs | 1428.8 kg Performance 0-60 mph 4.3 seconds. Top Speed 309 km/h | 192 mph Similar top speeds Engine Engine Configuration V Cylinders 10 Aspiration/Induction Normal Displacement 5.00 L | 305.1 cu in. | 5000.6 cc. Horsepower 528.00 HP (388.6 KW) Torque 560.00 NM (412.9 Ft-Lbs) HP to Weight Ratio 6.0 LB / HP (Vehicles with similar ratio) HP / Liter 105.6 BHP / Liter Vehicles with similar horsepower and weight Standard Transmission Gears 6 Transmission Manual Dimensions Fuel Capacity 23.8 Gal Seating Capacity 2 Doors 2 Exterior Length 169.301 in | 4300.2 mm. Width 74.801 in | 1899.9 mm. Height 45.901 in | 1165.9 mm. Wheelbase 100.801 in | 2560.3 mm. Front Track 63.901 in | 1623.1 mm. Rear Track 62.701 in | 1592.6 mm. Vehicles with similar dimensions Steering Power Steering Turning Circle 37.70 Brakes Front Brake Size 365.001 mm | 14.4 in. Rear Brake Size 335.001 mm | 13.2 in. Tires / Wheels Tires Front : 235/35 Z R19 Rear : 295/30 Z R19 Wheels Front : 9 x 19 Rear : 12 x 19 that could make your drawings look more professional and with detailed specs you could download software to estimate what the power the car's gonna make or what it's gonna run. check this out if you want http://www.roadsters.com/software/ |
Oh, go into more detail. I like it. Thanks for the site. I'll try to do that sometime soon. Thanks again SV. By this weekend I should have my "car stats" page updated.
G-man422 |
Just updated. more drawings, and cars.
Weight 3150 With composite panels? Lambo got the specific power, but the weight thing (like the F1) is ludacris! HELLO! carbon fiber=5x strenght per weight of steel! 2000 pound civic should weigh like 700 considering aluminum block and increased body strength so it doesn't crack. WTF!
Im currently building a 300 hp. version of a 4- stroke Honda motor converted to two stroke with a turbo n intercooler setup meant for a 1.8 liter. The unibody structure is of epoxy and glass cloth w/honeycomb core. My weight is projected at 400 lbs. plus occupant.
THAT is as real as it gets. your 800 hp. V10 in a 800lb. vehicle is only allowing like 300 pounds of weight to haul around a big block. there's no f-ing way. Are u gonna use unobtanium for your chassis(LOL)! Last edited by Carbon Fibre; 05-20-2006 at 11:51 AM. |
