Go Back   Automotive Forums Car Chat > Volkswagen > GTI
Old 03-26-2006, 07:37 AM
Diggers Diggers is offline
Question MK3 not starting
Hello,
I have a 1995 8v MK3 GTI. For a couple of months now it's been pulling back every so often when I've been driving. Lately though it's had trouble starting and is getting much worse. Originally I thought it may be the HT leads breaking down but these have been changed along with the rotar arm and distributor cap. When the car doesn't start the coil has no volts going to it.
If anyone has any suggestions I'd be really grateful.
Thanks
Old 07-30-2006, 07:48 PM
kutza kutza is offline
Re: MK3 not starting
ignition switch maybe worn out. Does the chime come and go out if you wiggle the key in the switch?
Old 03-18-2007, 05:15 PM
irely72 irely72 is offline
Originally Posted by Diggers
Hello,
Thanks
It sounds like the factory fitted immobiliser is cutting off the supply. There is a chip in the key which must be recognised by a black collar ring which surrounds the ignition, unclip this and try it then replace it. The ECU might also need reprogrammed.
Old 03-20-2007, 10:20 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Mist water on the coil when the car is running, if it arcs or dies replace it.
Old 03-21-2007, 03:40 PM
Thanx for the reply, got a feeling you could be spot-on as the problem gets worse in wet weather or after I go through a car wash. Will keep you posted after I get the coil replaced...
