| Let's get Technical! Discussion for hardcore in-depth motor heads! |
95 honda accord keeps cutting out and backfiring..
hi there, i have a 95 accord, its driving me crazy, while driving it starts to cut out,and slows down, then when i push on the gas it backfires, it starts to go when i slam on the gas at first then it will be fine, ive taken it to 3 auto shops, had a tune-up, then had a fuel filter put on,then it still did it so the next place said it was the fuel pump, had that put on, still does it, then someone said check the catalict coverter, thats fine, so what else could it possibly be? they wont do a computer diagnostic because the check engine light hasnt came on, any suggestions please?? the coil, timing? anything? all i want to do is fix it and sell it! thank you
Re: 95 honda accord keeps cutting out and backfiring..
thx , marty |
i had a similar problem with my civic. it has a jdm b18b swap. when the engine was cold, it would start and run fine. when it was warmed up the idle was low, sometimes it would kinda gasp and then die, or when driving in gear it would feel like it was surging, or when accelarating the revs would go up but the power just wasn't been transferred to the wheels very efficiently, then all of a sudden it would hook up and run fine. the problem was in the distributor. when i replaced it a year ago i didn't screw the rotor to the shaft, eventually, the rotor started wobbling and missing contact with the cap, which ended up frying the igniter, once i replaced the cap, rotor and igniter it runs just fine. of course this time i screwed the rotor down, because now i know how to turn the rotor around to get to the screw hole. so, maybe it has something to do with the dizzy
I have the exact problem! I have cleaned out and replaced the egr valve it didn't work replaced the exhaust and fuel filter, throttle body position sensor was replaced, I replaced the plugs and wires twice in six months, and recently switched out the ignition coil. I am close to giving up after 3grand into it. Nothing yet it's smoother but still cuts out and still backfires. I need help as well.
Ps the cap and rotor are new as well as a new water pump and belts. Last edited by Mcorson1101; 08-06-2013 at 01:32 PM. Reason: Forgot last sentence |
