Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-25-2006, 06:22 PM
mayohartman mayohartman is offline
Keyless Entry Program for 2005 Camary
Can anyone give me the keyless entry program for a 2005 toyota camry. I tried the same program listed on the internet for 2002 to present but I am not having much luck. Matt
Old 03-25-2006, 08:32 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Keyless Entry Program for 2005 Camary
If a Camary is the same as a Camry - this is the procedure for the 2002-2005 models:
1. Start with the following conditions: You are in the drivers seat.
a. Key is out of the ignition
b. Driver door is open (all other doors closed)
c. Driver door is unlocked (other doors don't matter)
2. Insert and remove the key from the ignition twice within 5 seconds.
3. Close and open the drivers door twice within 40 seconds.
4. Insert the key into the ignition and remove it.
5. Close and open the drivers door twice within 40 seconds.
6. Insert the key into the ignition.
7. Close the door
8. Turn the key in the ignition on and then off.
9. Remove the key from the ignition.
10. The power locks should automatically cycle once to indicate that you have successfully entered program mode.
11. Within 40 seconds of the entering program mode.
a. press both transmitter lock and unlock buttons SIMULTANEOUSLY for a duration of from 1 to 1.5 seconds.
b. within 3 seconds, press the transmitter lock button for more than 1 second and release.
c. If the transmitter has been sucessfully programmed, the power locks will automatically cycle once. If they cycle twice, the remote has not been accepted.
d. If multiple remotes are to be programmed, repeat steps A-C.
12. Open the driver's door.
Are you sure you have the correct remote for the 05 Camry?
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
