Old 03-25-2006, 04:41 PM
dwitczak dwitczak is offline
Where is the Idle Air Control Valve?
I can not find this item to replace. 1996 Blazer, 4.3 liter 4x4.
Thank you
Old 03-25-2006, 06:45 PM
jsgold jsgold is offline
Re: Where is the Idle Air Control Valve?
They are mounted on the throttle body. A round valve with a w/p connector running into it. Has two screws holding it in most of the time. They are expensive, be sure it is what you need first. Might need cleaned, or may be another item causing your problem. Poor idle is caused by a lot of possible items, too many to list.
I used to be indecisive, now I am not so sure.
