keyless entry
Can anyone please help me program my remote to unlock , lock and open the sliding door . The Number is GM 10245951. I have tried all I can think of.
Re: keyless entry
I believe you will find the instructions over in the Pontiac Montana Forum. Here is a link: http://www.automotiveforums.com/vbul...d.php?t=160122 Let us know what happens. Take Care,
Greg A. 2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010) 1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010) |
Re: keyless entry
There are different remotes, but they should be interchangeable, since they all have the same 4 button circuit board, even if its a 2 or 3 button remote.
10245950 = LOCK & UNLOCK 10245951 = LOCK, UNLOCK, SLIDING DOOR 10245953 = LOCK, UNLOCK, PANIC, SLIDING DOOR Important! Once the BCM enters program mode, all transmitters must be programmed at the same time. Any transmitters not learned at this time will be erased. 1) Remove the key from the ignition cylinder 2) Remove the BCM PRGRM fuse from the fuse panel 3) Close all the doors 4) Close the liftgate 5) Turn the ign lock cylinder to the ACC. position 6) Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second 7) Open and close front passenger door A chime will be heard when the system enters the BCM programming mode IMPORTANT! After 7 seconds a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming. 8) Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds 9) Repeat the previous step on each additional transmitter to be programmed. 10) Remove the ignition key from the ignition cylinder 11) Install the BCM PRGRM fuse back into the fuse panel.
Replacement keyless entry remotes available here - up to 90% off - All makes/models from Acura-Volvo, 1988-present - http://www.OriginalKeyless.com |
Re: keyless entry
2000 Grand Prix GT w/ gold package. K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe 2004 Chevy Trailblazer EXT Keep on Keeping on... |
Re: keyless entry
yes, they are all identical circuit boards inside. Pop yours open, you will see 4 gold colored button circuits even tho it is only 2 buttons on the case.
