Old 03-25-2006, 02:15 PM
Young Chuck D's Avatar
Young Chuck D Young Chuck D is offline
Send a message via AIM to Young Chuck D
89 4cyl cav.. TEMP Light Comes on, heat/air smell like antifreeze... new thermostat?
its only 6 bucks so i went ahead and bought it... i was wondering if anyone could confirm a new thermostat would solve the problem...
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles]
Gone but not forgotten:
1995 Pontiac Grand Prix GTP[sold, 128k miles]
1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles]
1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles]
1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems]
1990 Hyundai Excel GL [died, 220k miles, died]
Old 03-25-2006, 07:04 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: 89 4cyl cav.. TEMP Light Comes on, heat/air smell like antifreeze... new thermostat?
the problem you're describing in your "thread title" doesnt exactly sound like a bad thermostat, was your car overheating or running hotter then usual?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 03-25-2006, 07:16 PM
thats the thing... its running the way its usually ran.. but now the temp light is coming on. only change i've recently made is a new catalytic converter (that had been put off for possibly too long )..... somebody told me thermostats can be damaged in cold cold weather... its been cold recently, i'm in maryland, usa....
so no i don't think its overheating but i could be wrong.
oh yeaaaaaa also i found a bottle of brake fluid that my stupid dad left under the hood by the AC compressor... it had fallen out of place and was right next to that big belt the spins on the side of the engine.. the belt burned a hole in the bottle and i fear some may have leaked out. that may have done something
Old 03-25-2006, 09:18 PM
hmmm, well if your car is overheating, i would think you'd definetely know it, and since its probably not overheating i would have to say your thermostat is fine, about the brake fluid, the only thing i think it could have done is spilled all over and made one hell of a mess, it may have gotten on your engine, and since your engine gets hot, it will of course burn the brake fluid and that would cause a smell, however it wouldnt smell anything like the anti freeze smell you described, are you positive it was anti freeze you were smelling?? now moving on to your temp light, are you sure your not just low on coolant?
Old 03-25-2006, 09:25 PM
94VL 94VL is offline
Get brake fluid on your belt and its ruined.It can slip causing the water pump to slow down.
Old 03-26-2006, 01:07 PM
|WYG|SS |WYG|SS is offline
y not try flushing ur radiator it could be clogged.
Old 03-27-2006, 12:58 PM
went to mechanic...
1 hose completely busted, another was swollen so i had those 2 replaced for 115.65 and will never go near that shop again.
apparently pouring cold water in a hot car is a no-no and my head gasket is more than likely blown.
the gasket is 24.44 at advance auto parts. my issue now is why the fuck do they want 600 dollars to change a little rubber plate with holes in it....?
Old 03-27-2006, 01:00 PM
went to mechanic...
Old 03-27-2006, 06:18 PM
Its all in the labor,and the markup on the parts (gaskets).Changing a head gasket isnt a 5 minute job,and then after the engine is put back together you need to purge the air out of it and check to make sure its not going to overheat/leak again.This all takes time,and garages get $60-80 per hour labor.You might work for free.....but remember,no matter whose time it is...time is still money.While you are doing the head gasket you cant be somewhere else doing something else...
Old 03-27-2006, 06:26 PM
well my buddy down the street who works on cars off the books but has alot of equipment and experience and what not... said he'll replace it for 200 and told me to go buy the parts.
Old 04-14-2006, 02:07 AM
blackwidow98 blackwidow98 is offline
Send a message via AIM to blackwidow98 Send a message via MSN to blackwidow98 Send a message via Yahoo to blackwidow98
check your heater core too that comes associated with coolant smell in the vents. was there any coolant on the passenger side floor?
the Black Widow
98 Cavalier RS
