Go Back   Automotive Forums Car Chat > Toyota > Sienna
Old 03-25-2006, 12:49 PM
romanchirva romanchirva is offline
2004 sienna vsc and track off problem
I have no check engine light or any malfunctions in my van, but when I start driving the VSC/Track off lights are coming on. I checked the brake fluid level and increased tire pressure to 5.1 Psi. What else can I do?
Old 03-28-2006, 02:26 PM
Doug Tatham Doug Tatham is offline
Re: 2004 sienna vsc and track off problem
Since the VSC uses the same sensors as the ABS, you may try resetting your ABS. With the engine off and the key in the on position, you press the button until it flashes three times. If the engine light comes on the VSC comes on as well, could your engine light bulb be burnt out? Hook up an OBDII reader and see if you have any engine codes reported.
Old 04-30-2007, 12:58 AM
I have retrieved 39436263 for VSC and 94 and 95 for ABS
Old 04-30-2007, 05:39 PM
What button I have to press?
