Old 03-25-2006, 11:57 AM
95camaroz28 95camaroz28 is offline
keyless entry programming
got a new remote and need some help programming any ideas?
Old 03-26-2006, 08:10 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: keyless entry programming
95 Camaro uses these instructions:
Programming procedure:
Ground the program input line by connecting a fused jumper at the Data Link Connector (DLC) from terminal "G" to terminal "A" (note: use terminal G and A for pre '95 12 pin DLC. A is the top right pin and G is the bottom left. Use terminals 4 and 8 for the '95 16 pin DLC. The 16 pin DLC connector is numbered top left (1) to top right (8) and bottom left (9) to bottom right (16) ). The Receiver will cycle the Door Lock Actuators within one to three seconds to acknowledge that the Receiver is in the "PROGRAM" mode.
Press any button on the Transmitter once. In response, the Receiver will cycle the Door Lock Actuators to acknowledge that a transmission has been received.
Press any button on the second Transmitter once. In response, the Receiver will cycle the Door Lock Actuators to acknowledge that a transmission has been received.
Remove the fused jumper from the DLC and verify system operation using all three Transmitter buttons.
Important
Always program both Transmitters when replacing a lost or damaged Transmitter. The first Transmitter Code programmed will always be in both memories until a second Transmitter is programmed within the same sequence.
The Keyless Entry System will not be operational if the program input line is left grounded.
Program only one vehicle Keyless Entry System at a time. If multiple vehicles are being programmed in close proximity simultaneously, it is possible that the same Transmitter could be trained to more than one Receiver.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 04-18-2006, 04:24 PM
97 ZR 97 ZR is offline
Will this work on a 97 Camaro?
Thanks
Old 04-20-2006, 09:44 PM
Xbox2202 Xbox2202 is offline
Send a message via ICQ to Xbox2202
No, they use a different system to set it up.
1994 Camaro V6 A4 - RIP 3/1/06
http://www.cardomain.com/memberpage/805164
1994 Camaro Z28 A4 - Bought 4/6/06
