Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-25-2006, 11:47 AM
dandie dandie is offline
brake problem 1990 ciera
have a 1990 cutlass ciera 3.3 engine real nice but right front brake sticks bad i have changed pads caliper rotor and wheel bearing all got so hot rubber parts were no longer there grease in ball joint gone have also changed master cylinder but still does same thing has a crossover master cylinder and does not seem to have aseperate proportioning valve do not want to spend any more cash on new parts till ican get figured out help and thanx
Old 03-26-2006, 06:57 PM
Mrbizness1 Mrbizness1 is offline
Re: brake problem 1990 ciera
Have you checked the r/f brake hose?
Old 03-28-2006, 08:09 AM
r/f brake hose looks ok are you thinking it may be collapsing inside
Old 03-28-2006, 11:29 AM
GTP Dad GTP Dad is offline
Pontiac Guy
I agree with Mrbizness1. This sounds like a bad brake hose on the front that is not allowing pressure to release back into the system from the caliper. Replace the hose and bleed the system. They do go bad on the inside from time to time.
