Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-08-2002, 03:51 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Talking no laughing matter
ok...i've been debating for a while on what to do to my civic..it is a 97 ex with 130,000 miles on it. i was thinking of doing ihe and spraying like a 50 shot just for fun. Right now the money isn't around for the turbo or anything. i am lucky to come up with 100 bucks extra a month. --job hunt in progress -- If i get a better job i am going to buy a nissan 240sx s15 chassis and drop in the sr20. so for about 5 or 6 grand i'll have a rear wheel turbo machine with tons more potential that my FF sohc. what i want to know is what steps should be taken to safely spray 50 shot on a high milage sohc. colder plugs, external coil, etc. would like some word from someone with experience....thanx for the help
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 07-08-2002, 04:54 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Simply put, possibly and engine rebuild. I know a 50 shot isn't too much, but still on an engine with 130,000 miles, it just seems a little risky to me. Now I have never run N2O but it just seems to me that it can play hell on your internals if you aren't careful. Maybe someone with more experience has a better answer.
Old 08-23-2002, 05:12 AM
Whitey001 Whitey001 is offline
Dam Where didi u drive it to Japan and back :greenchai
Old 08-26-2002, 11:28 AM
hondatool hondatool is offline
man just drop in a b18c1 and go to town with it....and plus parts are cheaper than for a 240 i believe....b18c1=gsr=most stolen engine in the US
Old 09-13-2002, 05:09 AM
SuperGreen95EX SuperGreen95EX is offline
To answer your question, I would say above all else, a rebuild! If you do not want to rebuild then I would upgrade the entire fuel system without question no matter what you do. If you a 50 shot on that motor with that many miles then you are gonna have alot of problems real fast!
"It ain't fun if you ain't scared"!
1995 Civic w/GSR swap and stuff......
99 Pontiac Trans Am w/ 4:11's
Old 09-13-2002, 09:34 AM
blowngsr blowngsr is offline
Send a message via AIM to blowngsr
I like the idea of the SR20DET but i would modify it just a little bit. Ok screw getting a 240 just put the "blacktop" in the civic i have heard it is possible w/o extreme fabrication plus that sun of a bitch would haul ass!!!! So in my opinion hold off on the juice and hold off on buying the 240 use all your saved money to have a gross ass civic.
Supercharger $2000, Destroying V-8's PRICELESS!!!!!!
00 GSR/JRSC/ICEMANCAI/DCHEADER/TESTPIPE/TANAUBEEXH/SKUNK2CAMGRS/street tires&11psi=13.6@105
Old 09-13-2002, 04:53 PM
-=BOOMER=-'s Avatar
-=BOOMER=- -=BOOMER=- is offline
Send a message via ICQ to -=BOOMER=- Send a message via AIM to -=BOOMER=- Send a message via MSN to -=BOOMER=- Send a message via Yahoo to -=BOOMER=-
Originally posted by blowngsr
Ok screw getting a 240 just put the "blacktop" in the civic i have heard it is possible w/o extreme fabrication.
A rear wheel drive engine in a Front wheel drive body? Don’t know about you but creating a drive shaft tunnel from front to back on a civic sounds like extreme fabrication to me.
Old 09-15-2002, 02:48 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Haha, exactly what I was about to say...I don't know too much about spaying on a Honda engine. I've sprayed for a while on V8s though...Not really too much to worry about, as long as the engine is in good tune. Really the only things that you have to be careful about are hitting the rev limiter while spraying, and your fuel system crapping out. And there are safety devices to protect your vehicle in each of those cases. So I would say go for it, except b/c like I said I'm not too familiar with Honda engines, I don't know how big a 50 shot is in relation to what they can normely handle. Just keep the shot relatively light and you should be set.
There's no replacement for displacement...No, not even a turbo.
Old 09-15-2002, 12:07 PM
Rice_destroyer Rice_destroyer is offline
a 50 shot of nitrous will be fine on your motor. just make sure you have at least 1 step colder plugs, and clean oil. after that it all comes down to whether you're gonna go with a wet or dry system. either one will be fine, but your stock injectors can only handle so much before they crap out. so IMO if you want to run more than 80 shots, which i know you wouldn't do, get a dry system.
for your info:
a buddy of mine has a 94 ex coupe with I/H/E and dry nitrous kit doing 75 shots, was able to hit consistent mid 14's all day long at the tracks. he was faster than most civics with B18c1 swaps.
94 SI, B18B1, port n polished head, SRP 9.2 slugs, Eagle Rods, Total Seal rings, ARP bolts, Nuformz blockguard, MSD ignition, apexi V-AFC(hack), PYR chip(8500 redline), 450cc injectors, bbk f/p, custom T3 kit w/MP equal length manifold, huge intercooler, restrictive 2 1/2' exhaust
next mod: Hondata+GM MAP
Old 09-16-2002, 09:14 PM
Front wheel drive tranny=200sx SER
