Old 03-24-2006, 11:54 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Talking Worked on my car today
Well, I just got done working on my Talon! Remember, I am getting ready to take the head off to get the gasket surfaces planed and valve job done. Got out all my tools and started pulling shit off. So I get all the little shit off and I was going to take off the exhaust manifold and turbo for some porting. I tried to unbolt the dp and then the turbo. No luck, they were stuck as hell. The impact and this 3 ft pipe now called the "torque stick" put over the wrench for some extra torque couldnt get them off. So I go to Wal Mart for some WD 40, but they were out so I got this PB Blaster stuff. That shit is bananas. A squirt of that and the torque stick worked wonders to get the rusty turbo and DP bolts. So I got the whole hotside of the head off tonight. Also, a head gasket kit is on the way here, it should be here by like Tuesday or Wednesday hopefully.
Ok, now for the questions that happened while I was doing this. First off, the manifold was barely bolted on (I wonder what that loud ass knocking was ). They were like finger tight. Also, some of the manifold studs came off with the manifold nuts. I'm thinking the stainless manifold nut kit from SBR is in my future, what do you guys think? Do the manifold nuts go on like head studs, hand tighten them and turque the bolts on?
So this turbo. I get to F around with the turbo bolt that broke off in it, thats why there was only 3 bolts. Also, correct me if I am wrong but dont all the 14b's have nongrouped fins? The turbo I pulled off has 6 groups of two fins. I will run a serial number check tomorrow.
I will do some porting whiles its out and I know where to find the info on porting, but what parts do you guys think I should port? I was planning on porting out the manifold and the 02 housing, but could I port anything in/on the turbo that would make a difference?
Thanks guys, the intake manifold is next in line.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-25-2006, 12:06 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Worked on my car today
I love pb blaster, i actually go in trouble for loving it too much...
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-25-2006, 12:09 AM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
port the manifold, the turbo exhaust housing, and the 02 sensor housing, that should be good enough the guy on plymouthlaser.com has a hell of a write up on porting your manifold and 14b. you need to pick up a bottle of anti sieze before you put that all together again or something of the sort
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 03-25-2006, 12:10 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Take the studs out of the head and we always replace them with bolts with a 1.25 thread pitch from the hardware store and they work wonderful.
The fins should be ungrouped... Maybe you have a special model from the factory?
You can port out the O2 housing a ton, you can port out your exhaust manifold and you can port the exhaust side of your turbo. (The exhaust inlet part where the manifold bolts up to it.)
Have fun and go crazy with it.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-25-2006, 12:15 AM
Thor06's Avatar
Jizzed In My Pants
Liking that bolt idea Blackcrow. I just checked on tuners, with TDO5 and grouped fins it should be a 16g variant, but I dont know. The serial number check tomorrow shall hold the answers. I'll read those porting deals and get crackin. Thanks guys!
Old 03-25-2006, 12:18 AM
ez1286's Avatar
Are you porting the head too?
Old 03-25-2006, 12:19 AM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
My turbo is ported and I have a ported o2 housing. So far I love them both. Im not seeing any creep at all(knock on computer desk). I'm thinking you might have a 13g..post a pic too(with serial#) if you can. Good luck and defiantly pick up the anti seize when its time to bolt it all back up( save headache's).
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 03-25-2006, 12:33 AM
Thor06's Avatar
Jizzed In My Pants
I dont think I will go crazy on the head porting, but atleast a good gasket match and exhaust runner polish will happen. Heres the shop:
Then heres the turbo:
I'm not thinking the 13g idea, I just read on tuners that they used a TD04LH or something.
EDIT: I just zoomed in on it with photoshop, definately says TD05H. I cant read the number on the top though.
Old 03-25-2006, 12:35 AM
ez1286's Avatar
I can't read the serial number. Maybe you should get a tripod
Old 03-25-2006, 12:52 AM
Holy shit the wastegate is almost bigger than the turbo!...
j/k
Your Talon looks exactly like my brothers and it has been in that same position for a little over 2 months now. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-25-2006, 02:17 AM
qwklil4 qwklil4 is offline
Definately a 16g. Kind; run the numbers and see
Nice garage by the way, so much space.
'what you got in that thing, some kind of rocket?'
Some guy on DSMTalk
Old 03-25-2006, 05:56 AM
ned032002's Avatar
ned032002 ned032002 is offline
Damn, if I had a shop like that I would be working on my Ford every day instead of every other day!!!
Old 03-25-2006, 08:11 AM
Thor06's Avatar
Jizzed In My Pants
Well, guess whos lucky day today is? I just went out and checked the serial number on the compressor cover. It is 49178-01420. Guess what?
Originally Posted by RaginAsian
1) I reused my stock intercooler by flipping it. But it was pretty tight. If you do this make sure you tighten all your clams, so they dont blow off.
2)checking the serial number on the intake side.
49178 - 01420 = Big 16g
49178 - 01520 = Small 16G
49178 - 01470 = Evo III 16g
3) It looks like you have everything... Did you get gaskets for your oil drian line?
Good luck with the install!
Yes, the shop is really nice. Solid floors and heating, two things I am not used to when working on a car. My mom owns a wreath company that only operates from October to end of December so the rest of the time its storage. My dad also uses it for his racecar shop. To the left of the hatch in the picture you can see the white roll cage for his dirt circle track car.
Old 03-25-2006, 10:56 AM
MexRocket's Avatar
MexRocket MexRocket is offline
I hate you... you already have a bigger turbo than me =( lol. good to hear that the problem with the knocking is just your manifold being gay. Have fun, PB blaster is so cool, It SO cool that I even stole a bottle from Elliott's house. lol
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 03-25-2006, 11:30 AM
Big 16g...thats damn sweet when expecting a 13g or 14b. Have fune with her..
