Old 03-24-2006, 10:12 PM
Sargento69 Sargento69 is offline
Send a message via MSN to Sargento69
a little help please!!
i have a b20 in my crx dx. i had recently purchaced a 91 si body. my question is that since i am running a obd-0 b20 (91 integra ls ECU) and the si is obd-0 too. Can i just connect the b20 into the si wiring harness?? if not what do i need?? your help is greatly appreciated!!!
°Sä®GëNTö69°
B20B POWERED '91CRX SI
Old 03-25-2006, 09:57 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: a little help please!!
Yeah you should be good to go man!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-26-2006, 05:42 PM
oh ok. that is what i was thinking since both set ups are 0bd-0
°Sä®GëNTö69°
Old 03-26-2006, 08:25 PM
Hybrid1990crx's Avatar
as long as you are using a obd0 intake manifold and obd0 dizzy i think you should be fine.
Old 03-26-2006, 08:58 PM
Then i am pretty sure that i will be fine because the dizzy is of of an 91 teg ls (obd-0). i am pretty confident that everything will go well. I already got my hasport motor mounts (for $250). i know i can use the axles i have they are about a year old. The shift linkage i am going to buy new. the only thing i have to do now is prep that si for the swap.
°Sä®GëNTö69°
Old 03-26-2006, 09:01 PM
kris's Avatar
kris kris is offline
Off playing with fire.
You don't need a OBD0 manifold. Any OBD manifold will work. It's all in the sensors.
Old 03-26-2006, 09:38 PM
yeah i kinda figured that out. but thanks for the input!!
°Sä®GëNTö69°
