Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-24-2006, 09:13 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
running rich
I did a search but I couldn't find the answer I was looking for. I just hooked up my autometer air/fuel gauge, it came with the car. Anyways, the gauge is telling me that the car is running rich, the gauge is on the last rich light. How would I fix the problem? thanks
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 03-24-2006, 09:27 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: running rich
get a wide band and read it accuratly, what you have is nothing but a light show
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-24-2006, 09:53 PM
Re: running rich
I know, I want to but I dont have the money right now. But I think the gauge says its rich for a reason right or is it a gauge that just shows whatever it wants?
1997 Eclipse GS-T
Old 03-24-2006, 10:05 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: running rich
if the gauge is reading all the way one way or the other and isn't moving, you installed it on the wrong pin on the ECU. I forget which one it is, but you just misssed the 02 wire.
now - 2000 civic
soon - 2002 is300
Old 03-24-2006, 10:13 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: running rich
Sigh... Boreing Friday!
DSM geek
Old 03-24-2006, 10:19 PM
Re: running rich
its pin 6 . the guy I bought the car from already had it hooked up but he cut the gauge wires so I wouldnt see that the car was running rich. the o2 wire is white, pin 6 and 7 both are white. Should I try the other white wire I dont want to screw anything up. I installed it how the direction said to, i checked and re-checked.
1997 Eclipse GS-T
Old 03-24-2006, 10:58 PM
Re: running rich
Did you make sure you had the 2g ecu diagram?? I'm looking for the one I used, but I can't find it.
now - 2000 civic
soon - 2002 is300
Old 03-24-2006, 11:07 PM
Re: running rich
yup, what I meant by pin 6 was pin 76. http://www.vfaq.com/index-main.html
1997 Eclipse GS-T
Old 03-25-2006, 12:31 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: running rich
Usually narrow band o2 gauges aren't accurate. If you have no boost leaks and aren't running bigger injectors i see no reason for running rich.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-25-2006, 12:55 AM
Re: running rich
well tomorrow I'm going to pull the spark plugs and see whats really going on. thanks
BTW... I think I'm getting some lifter tick. i know its nothing to worry about. When I bought car I checked the dip stick and the oil level was under the first notch. it took 1 1/2 quarts to fill it. some people just don't care, even though he is from a race team called team one.
1997 Eclipse GS-T
Old 03-25-2006, 08:30 PM
Re: running rich
Today I pulled out all te spark plugs and there is some carbon biuld up on them. the top of the piston is full dry gunk. So I think that the car has been running rich for quit a while. the next thing i want to do is change the stock coils which have over 100K miles on them to MSD coils. any ideas? thanks
1997 Eclipse GS-T
Old 03-25-2006, 08:39 PM
blk_srt's Avatar
Re: running rich
I dont think msd makes a coil for the 4g63, if you want anything other than factory IIRC your options are that aem coil deal, srb makes a cop setup, and theres a few that I'm probably forgetting
Mods:
Old 03-27-2006, 10:09 PM
Re: running rich
can someone give me a wed site where I can get an ignition. I tried to look for the srb one but no luck. thanks
1997 Eclipse GS-T
Old 03-27-2006, 10:12 PM
blk_srt's Avatar
Re: running rich
what do you mean ignition? Coil or msd or what?
Mods:
Old 03-27-2006, 10:13 PM
blk_srt's Avatar
Re: running rich
http://www.slowboyracing.com/shop.ph...a3f9f2b5c8269f there is a whole section on ignition on sbr
Mods:
