Old 07-08-2002, 02:06 PM
CivicRacerX's Avatar
CivicRacerX CivicRacerX is offline
Send a message via AIM to CivicRacerX
Arrow Clutch issue
99 Civic EX, ~50k miles
Just noticed this noise coming from my clutch recently. I haven't driven the car in a couple of weeks because it was in the shop thanks to my insurance company and their policy on stereo replacement. Anyway, so now when I disengage/engage the clutch pedal, I hear a squeak. It happens whether I'm in gear or not, so it doesn't seem to be the throwout bearing. Also worth noting is that I can feel a slightly different feedback from the pedal when it makes this noise. It just happens somewhere in the middle of the pedal's travel. Makes me think something is scraping where it shouldn't be. What are possible diagnoses for this, and should I be concerned?
Thanks
96 Honda Civic Daily - H22 Swap
82 Renault R5 Weekend Runner - Nearly Stock
83 Renault R5 Track Car - 13:1 CR, Archer Cams
Old 07-08-2002, 02:59 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
is that clutch cable or hydraulic?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 07-08-2002, 03:11 PM
Hydraulic
Old 07-08-2002, 04:32 PM
hmm... don't know what to tell ya. Perhaps something sticking in the pedal/plunger linkage? Try lubricating the pedal pivot and the pin that attaches the rod to the pedal, and see if that helps...
Old 07-09-2002, 04:15 AM
b16a3sol b16a3sol is offline
crawl down underneath your steering wheel and push the clutch pedal with your hand and see if the sound is coming from there. if it is then figure where it is and lube it up. if it is not, then jack the car up and have someone puch it in and out for you and listen for the sound. figure out where it is coming from, and try to lube that up.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 07-18-2002, 01:28 PM
SmoovSol SmoovSol is offline
Send a message via AIM to SmoovSol
its not th e pedal u weirdo, its the hydrolic actuator beside the transmition, it slide in the tranny where the rubber boot is. Oil that wit some wd40 and you'll be straight
Dont be Afraid Ta Be Different...
Old 07-18-2002, 05:39 PM
NuEra's Avatar
NuEra NuEra is offline
Banned
can you explain what the hydrolic actuator looks like?
Old 07-20-2002, 09:21 PM
look on ur tranny from the top view under your hood. You see that rubber boot? well to the left of that i believe u can push that into the tranny to the right. Oil that up nice and good, or if ur gettin a new clutch tell em to make sure they grease that, they usually do but sometimes get lazy....
98 Cavalier z24 clutch issues m.r.rodriguez Cavalier Problem Diagnosis 0 08-09-2010 08:51 PM
newbie with clutch issues jsrunner Jetta/Vento/Bora 4 09-29-2004 04:14 PM
!!!!!please help 240sx clutch issue!!!!! asuka02 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 5 09-22-2004 07:51 PM
Frustrating clutch issues pete-graham Accord/TSX/Accord Hybrid 2 09-12-2004 03:14 AM
Clutch Issues Street Shark GTV6 Tiburon | Tuscani 4 05-14-2004 08:10 AM
