Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-24-2006, 05:15 PM
godaddy20 godaddy20 is offline
Question 1999 Rodeo 3.2 code 301
ok, simple question, my daugher's 1999 Rodeo 2wd, LSE has come up with the code of 301, and I was wondering, standing at the front of the engine, which cylinder is #1??
Old 03-24-2006, 05:47 PM
surferfletch surferfletch is offline
Re: 1999 Rodeo 3.2 code 301
On my '97 3.2L, it goes 1,3,5 on the passenger side of the engine, from front to back, and 2,4,6 on the driver's side, again front to back. Someone will have to verify this for 98+. It should be in the archives. Good luck!
Old 03-24-2006, 05:51 PM
From the FAQ page, it is the same.
Old 03-24-2006, 07:59 PM
rodeo02 rodeo02 is offline
PO301= misfire cyl #1. Yep, #1 is front/left. Could be a cracked intake manifold gasket causing a vac leak & lean misfire. I've never heard of an isuzu coil-over going bad, but you could swap coils to see if the problem follows the coil. My bets are on a bad IMG.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-24-2006, 09:35 PM
ok, thanks guys. and I did look at the FAQ pages first, but I guess I didn't look enough. and Rodeo 02, you gave a diagnosis that I really did not want to hear, but thanks for the suggestion, I will check into it.
Old 03-24-2006, 10:18 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
I got that code(and others) for my IMG when it went. It's not really that expensive to get fixed.
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 03-25-2006, 08:26 AM
amigo-2k amigo-2k is offline
Isuzu Guy
same here. I had a misfire code when I had the IMG replaced.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-25-2006, 08:31 AM
highlandlake highlandlake is offline
Joel
During the life of my '97, two coils have gone bad. One by the previous owner five years ago, and one I encountered last year. Road salt was the culprit on the last one. Got the misfire message code I believe.
I like your suggestion about moving the coil around to check it. Should be careful when removing the wire harness though. The plastic catch breaks real easy, I have a cable tie holding mine on now.
For what it's worth, I bought an extra used coil on e-bay and it's in the glovebox as a spare. Paid about $20, tested it first, its a winner compared to the cost of a new one. Piece of mind.
'65 Chevy Malibu SS
'06 Pontiac Vibe (a dead deer fits nicely in the back)
'04 Ford Escape
GMC S-15 4WD
'57 Chevy 210 post sedan
'51 Ford F2 pickup
Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD.
Old 03-25-2006, 08:32 AM
It's really not a difficult repair to do yourself. Parts are cheap and it just takes half a day. How much have you payed at the shop to have it done?
Old 03-25-2006, 03:31 PM
ok, so I went and replaced the IMG myself, and it seems that the CEL might stay off ( I hope). but my question now is, normally when the IMG goes bad, when you get it removed, it is fairly obvious to locate the bad spot?? The gaskets that I replaced all looked good, as far as I could tell, and that is why I am asking. BTW, I went ahead and replaced the whole set of gaskets, and it was a not too hard for this fat, white boy.
Old 03-25-2006, 05:03 PM
Good deal!
Old 03-25-2006, 05:44 PM
marcre's Avatar
When I had mine replaced they showed me the old and there was a section broken off. Hopefully all is well with your Rodeo now. It's cool you were able to fix it yourself.
marc
My Rodeo
