Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-24-2006, 02:59 PM
gotbitbyamoose gotbitbyamoose is offline
e85
i was wonder what it took for a car to use e85 because my friends 89 ranger rover and 86 dodge truck can use with no problem and he hasn't done anything special to them, can any car run on it, does it require a certain compression ratio or what?
Old 03-24-2006, 06:33 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: e85
Generally it involves replacing all the rubber o-rings with synthetic ones to prevent them from breaking down. There are also tuning requirements that are incorporated into the computer that configures the engine for the properties of ethanol. It is not something that you can do on your own.
Old 03-25-2006, 10:29 AM
|WYG|SS |WYG|SS is offline
Re: e85
not all cars can use it. www.livegreengoyellow.com this might help u on which cars can use it. if u got a car that says it can use anykind of gas then u can use it. most of the new cars can use it but not all of them. i think it starts with 2000- preasent. if i want to use it in my cars i have to drive too a different city like 60 miles away
Old 03-25-2006, 05:27 PM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
Re: e85
ACTUALLY....it depends on what kind of alcahol it is, you might be able to use it in an injection system OUTSIDE of your stock system, I'm thinkin about it for the S/C to up the octane and cool the combustion charge. One of the two types of alcahol is a corrosive, so the experts recommend, the type that isn't corrosive (I thing thats the ethanol, but I'm not sure, more reading to come).
Remember, you cant run it like normal gas, I'm talking about an alcahol injection system, which puts the alcahol in the intake, not through the injectors.
If this was confusing, just dont use the E85, it is bad unless you are set up to use it.
