Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-24-2006, 01:39 PM
magnum3456's Avatar
magnum3456 magnum3456 is offline
Banned
brake pad/rotor combo
What is a good, inexpensive combo for new brake pads and rotors...i'm willing to go ceramic on the pads if they're good.
Old 03-24-2006, 01:51 PM
joeuser742 joeuser742 is offline
Re: brake pad/rotor combo
I posted almost the same thing a couple of weeks ago. What I got back was to use the best ceramic pads(Bendex, Raybestos, or Wagner) and any cheap rotors, or slotted rotors if you want. I'm getting the parts next week.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
Old 03-24-2006, 02:04 PM
blazee's Avatar
blazee blazee is offline
Problem?
Magnum3456 posted this same question last week, too.
Use your other thread don't start a new one for the same question. Several people replied to your original thread.
Closed Thread
