Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-24-2006, 03:17 AM
GT500916's Avatar
GT500916 GT500916 is offline
Banned
Send a message via AIM to GT500916
here is my idling problem -VIDEO-
http://media.putfile.com/240sx-idle
note, i was not touching the gas pedal at any given time, from start to finish.
The car idles just fine, its probably a little to low at stop lights at about 600rpms but its fine and always runs perfect. Except when starting a car after it cools off, for instance the next morning. I changed spark plugs, changed fuel filter, still same. Timing is fine, last thing i think it could be is the fuel pump, doesnt pump enough fuel to the jets after it sitsand dries out a little? pump doesnt make any noise like its broken or anything.
also ill end up getting a new battery and probably a new started, because it does sound like its struggling to start. Ill see after the new battery what happens.
The rattle in teh video and car sounding like crap is because my stock exhaust is rustest through where the resenator is and its just hanging there. Im in a process of getting a new exhaust. As soon as i get my tax return. Id say in 2 weeks tops i should have a new exhaust cant wait!!
Old 03-24-2006, 09:59 AM
nissan_240sx nissan_240sx is offline
Re: here is my idling problem -VIDEO-
Fuel pump may be it.
Is it me or is your gas guage broken.. or your real low on gas lol
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 03-24-2006, 10:15 AM
GT500916's Avatar
Banned
haha yea dont worry im full now but it does the same thing on full tank of gas
Old 03-25-2006, 10:23 AM
zdude zdude is offline
Send a message via Yahoo to zdude
mine used to do that, but only when it was cold, and since ur from cali, i doubt its the same problem...
u joined on my bday
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
89 240sx (sold then died)
85 735i (Died)
95 Corolla (Damn Deer)
94 Renault Espace (gave away lol)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 03-25-2006, 03:54 PM
GT500916's Avatar
Banned
u joined on my bday
do i get a present for joining on your bday?
and what was your problem when it did that? because it has been cold here lately, but not that cold. Was it your fuel pump?
Old 03-26-2006, 04:01 PM
no it wasnt the fuel pump, its been so long i dont even remember if i fixed it. i did replace the O2 sensor, cap and rotor, upgraded to the 300zx fuel filter, changed plugs and wires, and that solved pretty much all the idle/run/emissions problems i had... you could try taking it in to a shop, most places will look at it for free because they think you want them to fix it.
sorry i cant help much
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
85 735i (Died)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 03-26-2006, 05:56 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
when it's cold is it hard to start? if so it is possable that your injuectors are leaking now into the cyl and making it hard to start .. as if it was flooded..Also if you can get a fuel pressure guage.. you can check your fuel pump and your injuectors just by watching the guage
Old 03-27-2006, 12:25 AM
GT500916's Avatar
Banned
no not hard to start, always the same
Old 03-27-2006, 03:13 PM
NiSmO_zt's Avatar
NiSmO_zt NiSmO_zt is offline
Send a message via AIM to NiSmO_zt
had same prob, i took the maf out and sprayed it with carb cleaner, then used compressed air and blew it out.
then locate the idle air control valve on passenger side rear of motor behind mani, and run the idle screw in all the way, and back out, it fixed my prob completely
had a friends car do exactly same, so i did that to it, and it fixed it also.
good L
my current 240--ka-t
Old 03-27-2006, 05:22 PM
you can spray the maf? thought that was bad
-Matt
NISMO
Old 03-27-2006, 06:15 PM
jdmdude15's Avatar
jdmdude15 jdmdude15 is offline
Banned
check all vacuum hoses then check ur throttle position sensor and cam positionin sensor see if the cps is loose
Old 03-28-2006, 03:38 PM
NiSmO_zt's Avatar
spraying maf not bad, just dont use an iron fist, all your really trying to do is get the surface dirt and crap off of it, the carb cleaner emulsifies the crap, and the air blows it away. ive blown out several, plus my z32 one with open resistor, and never had a problem.
Old 03-28-2006, 09:31 PM
GT500916's Avatar
Banned
ill try this out tomorrow if i get a chance. thanks!
Old 03-28-2006, 11:12 PM
ok, let me know how it goes nick. I might try it
-Matt
NISMO
