Old 03-24-2006, 01:57 AM
nickelnutz nickelnutz is offline
Unhappy Won't start
Tonight I dropped my friend off and had my car stall as if it ran out of gas at his place. Tried to get it going again but no luck.
We put fuel in the car so I know that there should be enough to get it going, the fuel pump kicks on, and we pulled a plug out and we do have spark. Now after quite a bit of cranking we pulled the plugs to check the spark and found that 3 out of 4 were still dry.
Basic info:
- '89 CRX Si 5 spd.
- SOHC ZC, stock except for a c.a.i.
- car was running fine 5 minutes before it stalled, no hesitations
or noises before it stalled
- plugs are less than 4 monthes old and came out looking good,
not burnt fouled
- checked all the fuses, they all look good
Anybody know why all the plugs weren't wet? Anybody have any guesses on what I can do to get it running again?
Thanks for the help.
Old 03-24-2006, 06:22 PM
Re: Won't start
More to add, just checked the ecu, it's throwing codes 16 and 17.
Old 03-25-2006, 01:23 AM
stewieaz stewieaz is offline
Re: Won't start
Code 16 = Fuel injectors
Code 17 = VSS- Speed Sensor
