Old 03-24-2006, 12:18 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
help me please. no spark
ok i got my si harness put in so now everything but the engine works. i had torewire the distributor but im possitive that that isn't the problem. so my friends dad who works on cars alot says it is the ignition. well the gears turn and everything when i try to start the car. it tries. and then i think it could just be the dizzy but i dont want to buy a new one until i make sure it isnt the ignition. if anyone can help me please do. thanks oh and there is a zc in the car.(crx) and i checked the spark plugs and tested them and there was no spark,please help.
Old 03-24-2006, 04:50 PM
ElbertR ElbertR is offline
Re: help me please. no spark
Did you mix up the 2 white wires to the distributor?
Otherwise the ignition coil inside the distributor could be bad.
91 Civic STD HB. Over 280,000 miles on car, estimate about 100,000 miles on engine (D15B1). Original 4-Speed Tranny swapped for DX 5-Speed. Power doors, remote entry, remote hatch popper, power windows. MPFI swap completed!
Old 03-24-2006, 05:44 PM
2poor2tune's Avatar
hwo would i know if the coil is bad? and i will try swap them right now. there is a thicker white wire on the dizzy and the harness side so i put those two together and was convinced they go together.
Old 03-24-2006, 05:50 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Dude, I just started putting my harness in today...isnt it a bitch!!!!!? I have never been so amazed by my car...Ill put the pics I took up..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-25-2006, 05:43 PM
2poor2tune's Avatar
ok i swapped the whitye wires and nothing new happened. no spark just turning over over and over again. please help and how do i know if the ignition coil is bad?
Old 03-25-2006, 06:38 PM
Swap the ignition coil with one from another distributor. It is the black part on top, it has 4 screws.
Could also be the ignitor module inside the distributor. It has 4 wires going to it and is held on by 2 screws on the bottom.
Old 03-27-2006, 11:41 AM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Take the 2 wires from the ignitor and hook them up to a low watt bulb then crank engine. If the light flashes then the coil is good. Replace the ignitor and you should be good to go. It happened to me after i did a tune up.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
