Old 03-23-2006, 08:29 PM
Tzer's Avatar
Tzer Tzer is offline
Simple Antenna Question. I've Searched :)
I couldn't find an answer in my searching so here it goes.
Is the antenna on my 99 GT SL supposed to go back down after switching from radio mode to CD? (Factory Infinity System)
Example.....
When I start or acc the car and it's in CD or Tape mode the antenna is down as should be. When I go to radio mode of course the antenna goes up.
Now should it go back down immediately when going back to CD or Tape mode or does it just stay up until the car is turned off?
Maybe there is a delay when changing modes before it returns back down?
Thanks for your time.
Tzer
1999 3000 GT SL 5 Speed - All Stock :/
Old 03-23-2006, 08:44 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: Simple Antenna Question. I've Searched :)
if i remember correctly, when you change back to cd, its suppose to go back down.
but i havnt had my stock radio in in a long time.
somebody back me up or correct me
Old 03-23-2006, 08:45 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
It's supposed to go back down.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 03-23-2006, 09:50 PM
Tzer's Avatar
Thanks for the fast replys.
I went and double check how mine works and it don't go down while switching modes. Only goes down after shutting the stereo or the car off.
So I dug out the Owners Manual and here's what it says..
Power antenna (if so equipped)
The antenna will automatically be extended when the radio power switch is turned ON while the ignition key is in either the "ON" or "ACC" position. The antenna will automatically be retracted and stored when either the radio power switch is turned OFF or the ignition key is set to the "LOCK" position.
Nothing mentions switching modes.
So I guess it's working properly according to whats stated above.
Thanks again. I guess I should have just dug out the book in the first place, but again. It don't mention nothing about switching between modes :/
How does the antenna operate with an aftermarket stereo? I'm considering upgrading
Tzer
Old 03-23-2006, 10:01 PM
youngvr4's Avatar
STREET RACING GURU
with mine, the antenna stays up ther entire time you listen to music, regradless if its cd or radio, you have to turn the stereo off for the antenna to go down
Old 03-23-2006, 10:18 PM
Tzer's Avatar
O.K. Thank you youngvr4
It's wasn't a big deal. Just something I noticed and was curious about.
I would think if it kept having to go up & down it would wear out the motor much quicker. (For those of us who use the radio like a T.V. Remote LMAO)
Tzer
Old 03-23-2006, 11:28 PM
Igovert500's Avatar
blue + red light magnet
I have an aftermarket stereo, but my attenna drops as soon as I switch to CD. So perhaps the difference lies in stock vs. aftermarket stereos/headunits.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-25-2006, 12:01 AM
AutostradaVR4 AutostradaVR4 is offline
igo's right, its controlled by the head unit. the deck sends the signal through the remote wire when it wants the antenne up/down.
see, with mine, its very high-tech. i have to turn the head unit off, they quickly get out of the car, walk to the antenne, and push it down about an inch so it catches and the motor retracts it lol...stupid broken track...
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 03-27-2006, 02:02 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
ya, my antenna has been having problems goin up and down all the time when i switch my aftermarket head unit from cd to radio. i think it just crapped out on me. anyone have an extra?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-27-2006, 02:18 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
I dont mean to hijack this thread but on a side not to Linbkr: where did you get your healight conversion and about how much was it. If you have a link or something that would be great, Thanks.
Old 03-27-2006, 03:12 PM
The antenna problem is a common thing. You can buy another from 3SX- http://www.3sxperformance.com/body.asp
Black 1997 3000GT
Old 03-28-2006, 12:17 AM
Linebckr49's Avatar
PM sent
93 3000GT base
