Old 03-23-2006, 06:58 PM
MNegas MNegas is offline
Angry Coolant Light On
I have a 96 Cavalier and there is coolant leaking everywhere. We replaced the water pump & gasket and there isn't a leak anymore. The coolant light is on and won't come off. We read the manual & it says to let it completely cool off and the light should come off. 6 hrs later and the light is still on. Has anyone had this happen to them? What should we do? Thanks a lot!
Old 03-23-2006, 09:35 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Coolant Light On
are you sure your actually losing coolant, or is your light just coming on?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 03-24-2006, 03:27 AM
muff34 muff34 is offline
Wouldn`t happen to be a low coolant light would it?
Life Is A Highway ,Enjoy The Ride
Old 03-24-2006, 05:33 AM
i'm not losing coolant now...there was a huge puddle under my car sat. morning....now we replaced water pump & gasket, let the air out and the light won't come off...is there something in the computer that needs to be reset? or should i let it idle & hope that it clears out on it's own?
Old 03-24-2006, 05:42 AM
it is the low coolant light on but everything has been topped up so i know it's not low and nothing is leaking out of it anymore...what's my next step?
Old 03-24-2006, 07:42 AM
you could try disconnecting your battery overnight, that might reset it
Old 03-24-2006, 09:43 AM
If you try the battery disconnect trick and it does not help then sensor in coolant reservoir may be sticking or may have gone bad. if it was not on before this happened I would think sticking . give the reservoir bottle a rap by the sensor see if that works
