Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 03-23-2006, 05:44 PM
chromefreak chromefreak is offline
no tail lights!!!!!!!11
ok so i am new here, heres the problem, 1993 seirra full size extended cab, i have no tail lights, and yes i checked the blubs, 4 ways work, signal lights work, checked for a ground(direct from battery) still nothing,replaced the headlight switch and now have power at the switch,i read something about checking where the wires come thru the fire wall, but the problem is i can not find the little box( the one that used to be located just above the fuel pedal)that the wires come out of, did gm change the harness? anyways, i am sure there is a short or broken wire somewhere in the line seeing as how it fried the switch and melted the grease out of it,maybe i am overlooking something but rather than just start cutting the factory harness and bypassing the problem by running a new wire direct from the switch to the tail lights i thought i'd see if someone here can help me out. feel free to email me at [email protected] any help would be greatly accepted
Old 03-24-2006, 08:37 AM
mareswj mareswj is offline
Re: no tail lights!!!!!!!11
I had the same problem with my 94. I found out when the cops pulled me over at night. SAme thing signal, brake and 4ways worked but no running lights.
I found that the connector above the bumper that connects the main harness to the lights had a bad connection. I unplugged it and some water came out. I sprayed with WD 40 and reconnected and now lights work fine.
Hope this helps.....
1994 Sierra K1500
K&N Air Filter
Gibson Exhaust
Old 03-24-2006, 12:45 PM
thanks for the reply i guess i forgot to mention that i had already checked for that as well, have no power getting to that main plug, just have to start tracing the wire back to find the short, thanks for the reply, any other ideas? send my way thanks, when and if i find the problem i will post it here incase anyone else has this problem in the future
Old 03-25-2006, 06:42 AM
Mr. Smith Mr. Smith is offline
Send a message via Yahoo to Mr. Smith
Check your fuses, you failed to mention that. Those light are controlled by the parking lamps fuse if I remember correctly. I had a similar problem hauling a trailer and it was raining real bad. Shorted out the fuse.
Old 03-25-2006, 11:48 AM
well i found the problem, the wire leading to the back of the truck was broken, a nice cheap and easy fix, thanks for the replys, this site is pretty cool, it helps when other people have had some of the same problems it can save alot of time and costly trips to the shop
