Old 07-08-2002, 03:20 AM
poweredbyhonda604 poweredbyhonda604 is offline
Black Lining: I cant do it!
I desperately need tips to paint the black lining on my Fujimi Integra Type R!
I've read the AF FAQ but am hoping for more information
Thanx!! (first post BTW, Great Forum!)
Life begins at 8500rpm!
Old 07-08-2002, 03:53 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Practice on an unpainted body, until you are comfortable with the technique. That way, you won't ruin your precious model, and you can try as many times as you want.
Now, add thinner to the paint to make ultra thin black paint. Use a very small brush, and pick up almost water-like paint. Gently touch the end point of a line, and let the paint flow along the groove itself. Tilt the body if necessary. Also, you might have to let the paint flow from both ends, or might have to drop some at the mid point. If the paint overflows from the groove, wait until it 's dried, then moisten a Q-tip with thinner and clean it.
When you actually do this on a painted body, use incompatible paint, so that the thinner won't dissolve the body color.
Hiroaki Fukuda
2.4 blowing black smoke cr_rider Mighty Max 5 12-31-2010 02:56 PM
Paint it black! Matt black supercars and DBS blacks mattbacon Car Modeling 1 07-09-2010 05:37 PM
AMG Black Series Christer Olausson Other Cars 2 03-08-2010 06:02 AM
96 GMC Jimmy black smoke, backfires, Timing? corhey88 Jimmy 38 01-31-2010 03:29 PM
Black LM!!! (is it!!!???) payso F1 23 10-16-2008 02:16 AM
