Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-23-2006, 02:16 PM
metalkiwis metalkiwis is offline
ignition switch 85
ok i never done this before. but i need to change out the ignition switch on my caprice. the stupid haynes book says its on the side of the steering column but im not seeing it. could it be mounted on the top of it? if so do i need to drop the column to change it?
Old 03-23-2006, 02:19 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: ignition switch 85
It's mounted on the top left side of the column. The attachment bolts are on the left side, but the switch itself is on the top. It has a wiring harness attached to it from the right side. You will need a 7-mm socket or box wrench.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-23-2006, 03:03 PM
thanks a ton. its right there. still kind of a pain to get to, but i should be able to handle it.
Old 03-23-2006, 06:04 PM
CD Smalley CD Smalley is offline
It will help if you lower the steering column.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 03-23-2006, 06:48 PM
yea i got the new one on, but still have problems getting it started. i dont know what to do now. maybe you can help me with this... when i turn the key forward the dash lights and radio come on, but when i turn to start it, it all goes out. but when i turn the key back to accessories, stereo works then. i think maybe its the wire between the solenoid and starter. all the cables from the battery are tight.
Old 03-23-2006, 09:31 PM
GreyGoose006 GreyGoose006 is offline
you probably know this, but except for the accessories cutting off when you try to start it, everything else sounds to be working ok. do you have a feedback carburator, of so, it should click (softly, open the hood and you might hear it). you probly just missed a wire or something.
Old 03-24-2006, 11:36 AM
i guess i have the feedback carb. it clicks softly when i turn it on. im going to check all the wires that lead to the starter today and hopefully its there.
