Old 03-23-2006, 01:00 PM
sportco sportco is offline
95 Metro Rough Cold Idle
This problem is driving me mad! The car idles extremely rough at cold start up then after warming up a couple of munites it runs great. I have changed the coolant temp sensor, Cap, Rotor, Wires, Plugs, all filters, and temp sending unit. I have also taken apart the electronic throttle control on the back of the TBI unit and verified that the electric motor inside works in both directions. Has anybody seen this before? The dealers in my area all have a different opinion.
Old 03-23-2006, 03:49 PM
geozukigti geozukigti is offline
Re: 95 Metro Rough Cold Idle
Does it idle about 1500RPM's when it's cold? The cold idle valve should bump it up to 1500-2000RPM's.
Old 03-23-2006, 03:59 PM
No. It idles about 300 to 500 rpm and acts like it is firing on 1.5 holes. The compression test I took was 200 across the board cold so its not a valve or lifter. The old plugs show no sign of poor burning and the head gasket checks out.
Old 03-23-2006, 08:58 PM
Sounds like your cold idle valve is toast, or plugged. Is your engine a 1.3 or a 1.0?
Old 03-24-2006, 10:41 AM
Yes, it is a 1.0. Where is the cold idle vale located?
Old 03-29-2006, 04:14 AM
ahoorakia ahoorakia is offline
I had that problem,on mine I tookmy ignition out and under rotor there is two wires and it was pinched and was arcing,I covered the the wire with r.t.v and it is fine now,mine was ideling ok but as soon as I gave it a little gas start acting up,until it warmed up and the it was ok.
