Old 03-23-2006, 01:20 PM
Russel Russel is offline
brake fluid to transmission
Hi, i accidentally put half a cup of brake fluid to my 98 accord's power steering reservior. would that cause major problem? please help!
Old 03-23-2006, 01:57 PM
Igovert500's Avatar
blue + red light magnet
Re: brake fluid to transmission
Drain it, refill it with the right stuff.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-23-2006, 02:05 PM
Originally Posted by Russel
Hi, i accidentally put half a cup of brake fluid to my 98 accord's transmission. would that cause major problem? please help!
sorry it's actually power steering. same solution. is it major work?
Old 03-23-2006, 06:57 PM
BNR34_V-SpecII's Avatar
BNR34_V-SpecII BNR34_V-SpecII is offline
hondas required to have their own honda power steering fluids.
i wouldn't recommend to do the draining work yourself.
wait, did you put into the transmission or power steering?
take it to the shop, price shopping first.
Vietnamese born and loved,
Love the beautiful ladies,
Do not believe in minimum wage,
Dream car: 2007 / 2008 Lexus LS 600h
(Been shown in Lexus commercials)
Old 03-24-2006, 06:49 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
If you didn't start it, just suction out the resevoir and refill it. If you did start it, you'll need to flush it out. I'd remove the low pressure return to the pump, direct it into a bucket or pan, start it up with the cap off, and keep adding the correct fluid as the level drops in the pump. After a pint or so has run through. put it back together and refill it with new fluid. It may take some time to work all the air out, it'll growl in the meantime.
A small amount of brake fluid won't hurt it usually, brake fluid conditions rubber seals and hoses, so it's not gonna attack anything, but it's hydraulic properties are different.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
