Old 03-22-2006, 10:21 PM
outlaws03 outlaws03 is offline
Angry ready to give up
94 civic surges at idle, misfires and is running rich. I have try MAP, and IAC, also check for vacum leaks. Anybody got any suggestions
Old 03-22-2006, 11:56 PM
ZedEx's Avatar
ZedEx ZedEx is offline
GO-FIGHT-KILL!
Send a message via AIM to ZedEx
Re: ready to give up
The Surge is either the IACV (Idle Air Control Valve) going bad. The IACV is located on the back side of the intake manifold right near the throttle body, it's not too hard to change. If that's not the problem, bleed your coolant.
Misfires could be your distributor rotator. Change your spark plugs/spark plug wires/distributor rotator/distributor cap.
Are you throwing any codes?
And don't give up man, everyone has these problems with their cars, it's really no big deal, just play around with it some more, and you'll get it.
-Wes
-2000 PY Acura Integra Type-R #686 - WhoRe
-1997 EGP Honda Prelude Type-SH - Daily driver
R.I.P Hypsi87:Andy Filson
Old 03-23-2006, 12:28 PM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
as far as the misfire also check for exhuast leaks near you manifold as well,and the idle surge i had the same problem and spoke with the dealer and they said the common problem is the fast speed idle valve located under the throttle body it cost about $60 at the dealer. it fixed the idle surge i had. i thought it was the iac as well but it didnt fix the problem, the fast speed idle valve did.
1993 HONDA CIVIC EX
BLITZ FRNT M3 SIDE BLACK WIDOW REAR
JSP TERMINATOR WING
17' MOTEGI SUPER SILVER RIMS
D16Z SOHC 1.6 VTEC
SKUNK2 INTAKE MANIFOLD
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
T25 CUSTOM TURBO KIT @ 7PSI
TUBULAR MANIFOLD
AIR TO AIR INTERCOOLER
ALCOHOL INJECTION
18002 TURBO MILES AT 218002 MILES GOING 140MPH FINALLY WENT
BUT, STILL GOT ME HOME
