Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-22-2006, 09:16 PM
88capriceclassic 88capriceclassic is offline
i dont know!
1988 brougham V8 305 4bbl. h-code 125k miles
new replacement carb
new water pump
new starter
tranny rebuilt 6 months ago along with a new torque converter
tune up 8 months ago(cap,rotor,wires,plugs,ignition coil)
new O2 Sensor
ok i took it to my shop that usually takes good care of my car and everything they also put on my new carb about 3 weeks ago,reset the computer,adjusted everything and what not. about a week later everytime i would start it it would idle VERY high so i took it back and they adjusted the fast idle cam.then the next day it still did it so i took it to autozone and one of the carb. specialists turned the choke about 3 cm. or somthing like that and it doesnt idle fast anymore unless its very cold outside but it idles fine when its warm. EVERYTIME i start it its like it doesnt want to stay runnin so i rev it up about 2 times WOT and it starts to idle fine. i took it to the shop and they ran codes and said that its either the carb or the camshaft.when it goes around 40-45MPH right after it switches into 4rth gear its like its not even accelerating or nothing it bounces and the lifters start tapping but it doesnt backfire.so i took it to the tranny place because i thought it was the TCC and he said its something in the ignition system. the check engine light comes on ONLY when im stopped at a light for more than 3 seconds or when im in drive stoppd and it doesnt go off until i turn the car off.ive checked all vaccum lines and all hoses and theres nothing wrong with them.
could it be the EGR(stock)?cat. converter(stock,looks rusty and makes a rattling noise when revving)?any help of solving this mystery would be appreciated.
Old 03-22-2006, 11:49 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: i dont know!
new water pump
new starter
new O2 Sensor
Need a little more info. What are the trouble codes (ECM codes)?
Could be a number of things.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-23-2006, 03:16 PM
Re: i dont know!
well i told the guys to write down the codes and they said "the codes those old cars bring up dont describe anything." all they told me is that it threw a carbureter code and a camshaft code.
Old 03-23-2006, 03:35 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: i dont know!
Could it be a vaccum problem? maybe a fuel problem.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 03-23-2006, 05:22 PM
silicon212's Avatar
Confoundingly Lucid
Re: i dont know!
Time for a new mechanic.
You can obtain the code yourself by jumping (shorting) the last two pins on the ALDL connector, turning the ignition to the RUN position (but don't start the engine), then counting the flashes as well as the pauses. Ignore code 12- it's going to display on anyone who obtains codes with the service engine soon light. The way the codes work is this -
flashes
short pause
flashes
i.e. a flash - pause - flash flash means Code 12 - a flash flash flash pause flash flash flash flash is Code 34, etc.
Each trouble code will flash 3 times, beginning and ending with Code 12. If you see Code 12 flash 6 times, then there are no touble codes.
Old 03-23-2006, 05:32 PM
silicon212's Avatar
Confoundingly Lucid
Re: i dont know!
Diagnostic Trouble Codes - 1988
Chevrolet
12 No Reference Pulse
13 Oxygen Sensor Circuit
14 Coolant Sensor Shorted
15 Coolant Sensor Circuit Open
21 Throttle Position Sensor (TPS) (Signal Voltage High)
22 Throttle Position Sensor (TPS) (Signal Voltage Low)
23 Mixture Control (M/C) Solenoid Voltage Low
24 Vehicle Speed Sensor (VSS) Circuit
32 BARO Sensor Voltage Low
34 Differential Pressure (VAC) Sensor - Voltage Incorrect
41 No Distributor Reference Signal
42 Electronic Spark Timing (EST) or Bypass Fault
44 Oxygen Sensor Circuit (Lean Exhaust Indication)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 PROM Error
53 Exhaust Gas Recirculation (EGR) Control Error
54 Mixture Control Solenoid (M/C) Voltage High
Old 03-23-2006, 09:40 PM
GreyGoose006 GreyGoose006 is offline
Re: i dont know!
if you have a computer problem for sure, just go buy a haynes repair manual for computers and trouble codes. it is only $15 and will answer a lot of your questions. i read it cover to cover just to try to understand how the whole system works.
Old 03-23-2006, 11:52 PM
Re: i dont know!
how would i stort or jump the connector to make the light flash?
