Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-22-2006, 07:51 PM
4G63t Power 4G63t Power is offline
BEP 50 trim vs 57 trim
Ok... Its time to upgrade and I have a problem... Which turbo should I get... I can get a brand new Bulleseye Power 50 trim or 57 trim. The thing is I can get the 57 trim for 100 bucks cheaper brand new. Im still on an AFC and plan to run 680cc injectors. Ive heard so many good things about the 50 trim. I have heard good and bad things about the 57 trim. What is spool difference between the two? Also in slowboys dyno test on tuners the 50 trim made more power. Can someone with experience with these turbos point me in the right direction. Which one is better for a street/strip daily driver. My hp goals are upper 300's pump and 400ish on race gas. Which would you guys go with taking into accout the 57 trim is cheaper and im still on the SAFC. Thanks... Ryan
AWD sold
New car*
90' Eclipse Gs-T
Shaved head with rebuilt motor
Slowboy racing limited slip
compression 165 across the board (:
Fully ported Big 16g with 34mm flapper
Precision racing Fmic
Slowboy Boost controler set at 15lbs
Custom 3 inch turboback
Fully ported o2 housing
Ported 2g manifold
Slowboy racing UICP
3 inch hard intake pipe
SAFC
Autometer carbon fiber gauges
Putting down a solid 300whp
1/4=13.7 at 109
That mph is good for high 12's with traction (:
Old 03-22-2006, 08:23 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: BEP 50 trim vs 57 trim
Well, I wouldnt even go that big unless you are running DSM link. I've never heard anything bad about either the 50 or 57 trim, I would go with the cheaper one. How much are they?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-22-2006, 09:44 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
First off, you can't run an AFC and 680's and expect a decent tune. It will suck at idleing AND at boost.
Second, 50 trim and 57 trim turbos isn't really a turbo. It's a ratio of the specs on the turbo. Which ones are you talking about?
now - 2000 civic
soon - 2002 is300
Old 03-22-2006, 10:21 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
PTE-BB-SCM 50trim!!
DSM geek
Old 03-22-2006, 10:57 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
I've seen plenty of people running 680s on an afc with no problems. Hell I've seen people running 750s
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-22-2006, 11:18 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
The 57 trim is gonna lag worse than the 50 trim will on the street. If your goal is 300-400hp then I'd go with the 50 trim so that you have more bottom end power. Really, a 57 trim will only be good all around on a built motor. I've seen it and if I had the money to spend on a 57 trim and a built motor I would go that route. But, I don't, so therefore I would go with a 50 trim and use the afc and a gm maft for tuning it.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-23-2006, 04:37 PM
Thanks Blackcrow64 for giving me a straight answer. I am really get sick of this forum because nobody will give you a straight answer. I didnt post "can I run 680's with an afc" I personally have seen it done in two different cars. Sure, its not nearly as good as Dsm Link but I dont have 500 dollars for it right now. I wanted reviews on the turbos. If you dont know anything about them... Dont Post! Anyhow... any more input guys? Is the lag really noticable between the two turbos?
AWD sold
New car*
90' Eclipse Gs-T
Ported 2g manifold
Slowboy racing UICP
SAFC
1/4=13.7 at 109
Old 03-23-2006, 04:39 PM
blk_srt's Avatar
I wouldnt think lag would be more than 500 rpm between the two, really if you can I would go with the 57 trim that way you have room to work with
Mods:
Old 03-23-2006, 08:01 PM
kjewer1 kjewer1 is offline
AF - Advisor
The problem is the 57 trim isn't much bigger than a 50 trim, and it doesn't seem to do quite as well. Actually, it looks like it flows a couple pounds less than the 50 trim. Same for the 54. The 60 trim does like 52 lbs/min or something. It's easy to see why the 50 trim is so popular in light of this...
I like to follow Forced Performance's lead in this. They offered the Green (50 trim) and Red (60-1) and didn't bother with any of the wheels in between (54, 57, and 60 trim). I would agree with them on this one.
680s will work with an AFC, but there isnt much room for tuning. The injector compensation will be ~33%, minus another 10-14% to get somewhere near 10.5-11:1, leaving only another 3-7% of range on the AFC. This becomes a serious problem on race gas when you tend to lean out another 10% But it will "work."
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-26-2006, 10:08 PM
Kevin your the man... I thought the 50 trim was better but everyone says the 57 trim flows more... but from what ive seen the 50 is doing better. I have fallen into some extra funds and may dsm and link it after all... where can I get the best price on dsm link?
AWD sold
New car*
90' Eclipse Gs-T
Ported 2g manifold
Slowboy racing UICP
SAFC
1/4=13.7 at 109
Old 03-26-2006, 10:18 PM
blk_srt's Avatar
www.dsmlink.com
Mods:
Old 03-27-2006, 08:02 AM
TheRomer TheRomer is offline
i was going this same route so i can tell you my experience. I was going with the 50 trim, because it was a good size turbo at low cost (i was looking at the SBR 50 trim). But then a guy told me to get the SBR 57 trim because it was better. Well i went to call in my order, and i still was a little iffy on the turbo i wanted, i couldnt really decide. I talked to this guy named marc at SBR when placing my order. He had a 2g gsx that ran 11's, so he knew his stuff. I told him i was probably gonna go with the 57 trim, and when i did he said "may i ask why you are heading towards the 57 trim... from experience the 57 trim is not as good as the 50 trim, it lags more and gives you the same power as the 50 trim" or words to that affect. He told me people complained about the 57 trims lag. He told me that on race gas the 50 trim could get a little over 400 whp, and on pump around 350 or something like that (dont exactly remember). Anyways, i didnt get either but thats my problem. The 50 trim would be much better in your case because you get basically the same power, but without the lag. i hope this helps.
Chris Winchell
95 GSX 12.5 ET with a 1.9 60' at 115 mph
Actually have traction this year
90 TSI <Project Acer>
2.0L, 2400 lbs AWD, t-67 goodness
