Brake Bkleeding
I lost all brake (rear) when a metal brake line rusted thru, I changed or replaced the brake line, now how do I reset the brake light and anti lock lights also I want to know how to bleed the brakes. Any
help would be appreciated greatly. 1999 Ram 2500 Deisel 4 by4. Quad Cab.
Re: Brake Bkleeding
Bleeding the brakes is easy but there are several step to it and pictures will help greatly. I rec download the service manual in this section and just follow it, you'll have no problem. Remember to drain the fluid reservior and use all new fluid. You'll need an assistant to step on the brake pedal while you open the line and drain the fluid. Let me know if you have any questions.
Re: Brake Bleeding
Spelt bleeding wrong, anyway had to change the rear blake cyclinders as the bleed ports were rusted in. Got everything working at this time .Thanks for the help.
