Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-22-2006, 06:24 PM
dgi007 dgi007 is offline
my Poor Staurn
i have a 97' saturn SC2 and the miles are starting to get up there ( 270 000) and i have noticed its performance going down hill ... does anyone think running premium in it would improve this ... and is it good to like switch back and forth... ( i might not be able to afford it ) Or if anyone else has any ideas they would be much appreciated !!
\thanks
Old 03-22-2006, 07:11 PM
Cat Fuzz Cat Fuzz is offline
Re: my Poor Staurn
Premium won't help at all. About all you can do is make sure you tune it up now and then and change the oil.
When was the last time you changed the spark plugs and wires? SES light coming on?
Old 03-23-2006, 11:18 AM
Re: my Poor Staurn
i just changed them probly 2 months ago and i get my oil changed every 3000 maybe i should just try and drop a new motor in !! giver her some nutz \!!!!! any way thaNKS
Old 03-28-2006, 03:42 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
Re: my Poor Staurn
well what about your coolant sensor and a piston soak? your compression is probably dropping and could be because of the piston rings.
what about the exhaust? there are several things that need to be looked at first before getting a new motor.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 04-04-2006, 08:14 PM
nightbird nightbird is offline
Wink Re: my Poor Staurn
How old is your catalytic converter? Mine was clogged. Engine was choking at higher speeds. Car guys on radio suggested testing exhaust back pressure. I called GM and found catalytic converter has life of 70,000 miles, I was at 100,000 plus. I just replaced converter and car stopped choking.
Old 04-10-2006, 01:14 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: my Poor Staurn
My Saturn is at 182K. so far so good. as far as engine is concerned it has been really good to me, but changing the cat probably is not a bad idea
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
