Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-22-2006, 04:12 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
dropped Fuel Pressure?
I installed a Aeromotive fuel regulater, with gauge, as well as a Walbro 255HP, and a fuel pump rewire, and i was wondering... When the car is off after running, the car slowly looses fuel pressure, after about an 25ish min, its back to 0 psi... and when i start the car, it has to crank a little before starting, is this normal for a aeromotive FPR? walbro255hp? there are no noticible fuel leaks... just concerning me. any help?
Old 03-22-2006, 04:50 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: droped Fuel Prussure?
fuel pressure usually goes down after your car sits for a while. As long as its on an instant thing I wouldnt worry about it
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-22-2006, 04:59 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
it goes down, but there should always be a decent amount of pressure there. There is a problem, i just can't think of it.
now - 2000 civic
soon - 2002 is300
Old 03-22-2006, 05:11 PM
blk_srt's Avatar
Leaking injector/s is about the only thing that it could be unless you somehow got a bad regulator
Mods:
Old 03-22-2006, 08:15 PM
Black99GST's Avatar
when i got the regulator, the 1/8th pt hole (where the gauge screws in) it needed to be rethreaded... could that be the problem? i also used Teflon (s/p) tape on the threading for the gauge... pressure Drops tremendiously slow... but it drops all the way to 0 on the gauge... but the car runs FINE! it just takes a second or to for it to start when its cold (fuel pressure settled @ 0)
Old 03-22-2006, 08:52 PM
ned032002's Avatar
ned032002 ned032002 is offline
If he had leaking injectors then wouldn't the car start easily after sitting for a while just because theres already fuel in the cylinder? Idk I'm just curious if this is possible.
Old 03-22-2006, 08:57 PM
blk_srt's Avatar
Probably but what I listed are possible causes for fuel pressure drop. I guess it might not strat right away since gas doesnt burn in a liquid state
Mods:
Old 03-22-2006, 10:54 PM
Black99GST's Avatar
hmm... so what do you sugest i do?
Old 03-22-2006, 10:59 PM
blk_srt's Avatar
do a leak down test if you can but I would probably just live with it
Mods:
Old 03-23-2006, 05:36 PM
Black99GST's Avatar
Re: dropped Fuel Pressure?
i'll just live with it... it only takes a secont or two to start... so... EH... thanks guys!
Old 03-25-2006, 09:01 AM
racerh03's Avatar
racerh03 racerh03 is offline
Send a message via AIM to racerh03 Send a message via Yahoo to racerh03
hey man my car does the same thing i just installed a walbro 255 and a sard racing FPR...
92 240 sr20det bolt ons t28 stripped hatch (white knight)
91 300zx tt daily driver stillen exhaust, stillen down pipes jwt ecu, 18x10 rear 18x8.5 front adr wheels hks line controller etc..
