Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-22-2006, 12:45 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
91 GSX help
Alright so I finally have my 2.3 stroker together and back in the car. Everything is hooked up correctly and all is good. Now here is where I run into a problem. When I try to start the car the starter just turns like it's not grabbing the flywheel. So I swapped the starter out with a new one and same thing.
I called the guy from the shop here and he said just try to get the flywheel to spin alittle bit because it might need to slip down into the groove.
So my car at this point is jacked up in the front and the driveshaft is disconnected right before the rear differential. I put the car in gear and turn the wheels, only the wheels are turning much to easy and the engine is turning as well.
Now the car is definately in gear and I tried it in all gears including reverse and got the same results. The car even when it is in gear is simply not in gear. So I think maybe I hooked something up wrong? Any idea's as to what could be causing this and if it's related to the starter issue?
1991 GSX 2.3 Stroker
Old 03-22-2006, 06:55 PM
defiancy's Avatar
Re: 91 GSX help
Okay no worries about the spinning thing. Some one was nice enough to clue me in on what an open differential was.
But we shall see about the starter position.
Old 03-22-2006, 11:42 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 91 GSX help
Any teeth on your flywheel broken or worn down to the point of needing replaced?... Or are you running a new flywheel on it?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-24-2006, 02:41 PM
defiancy's Avatar
Re: 91 GSX help
Flywheel is the stock one that came off, but it was completely resurfaced and when I inspected it it was just fine and had all the teeth.
On another note, weither this is related to this problem or not. Most of my electronics are not working on the car. The guage glows and I get warning lights, but my headlights don't work nor do any of my interior lights or my windows up or down.
Old 03-24-2006, 02:46 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: 91 GSX help
so the starter spins but doesnt grab and you replaced it so thats pretty much ruled out, only thing I can think of is something is not fully seated. Make sure the tranny is flush with the block and that the flywheel is fully seated and the starter to
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
