Old 03-22-2006, 01:01 AM
welfarepc welfarepc is offline
engine wont start
So I got off work, drove to a buddys, came back outside, and the engine wont start. it turns over. took off distributor cap, cleaned the connections, retried, no go. took off gas line, turned car on, gas sprayed out, so its getting gas. what should i check next? any suggestions are appreciated. thank you.
Dan
Old 03-22-2006, 02:55 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: engine wont start
If your sure your getting fuel, check to see if you are getting spark. Pull out one of the spark plug wires from the head and hold it up to a suitable ground, like the chassis and see if there is any spark. If there is none than you need to trace which part is defective in the distributor and go on from there.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 03-25-2006, 05:12 PM
good call, thats exactly what i did. no spark. got a used distributor and it works now. damn those are expensive.
