Old 03-21-2006, 10:24 PM
mrgofast21018's Avatar
mrgofast21018 mrgofast21018 is offline
Send a message via AIM to mrgofast21018
wiring sucks
so i need some help with doing the wiring on my b16 swap. mainly the vtec solenoid, the radiator fan motor, the map sensor, and then one of the connectors on the distributor. please a website or something? thankeeeeee
gimme some time. ill think of something witty and clever to put here.
Old 03-21-2006, 10:43 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: wiring sucks
www.google.com
Old 03-21-2006, 10:49 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: wiring sucks
HAHA, you beat me to it!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-22-2006, 01:34 AM
Coricivic's Avatar
Coricivic Coricivic is offline
Send a message via AIM to Coricivic
Re: wiring sucks
if you get an si harness that will take care of everything but your vtec solenoid, knock sensor, oil pressure sensor, and your 2nd 02 sensor. go <a href="http://www.hasport.com/Tech/Wring/EFSi-VTEC.PDF">HERE</a> for what pins on the ecu to wire those into.
