Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 03-21-2006, 10:03 PM
CREWMEMBER20X CREWMEMBER20X is offline
Exclamation 1995 5-speed problems
I have a 1995 mystique 5-speed and you have to pump it to get it in gear, pump the clutch to stop and take off again. I think its the clutch slave cylinder (any suggestions) Where is the slave cylinder located
Old 03-22-2006, 03:33 AM
KimMG KimMG is offline
AF - Advisor
Re: 1995 5-speed problems
Do you mean you have to pump the clutch pedal? How's the clutch fluid level? Could be a bad clutch master cylinder. If the slave cylinder is not leaking then it should be ok.
Old 03-22-2006, 11:05 PM
Yes i have to pump the clutch to put in first gear reverse, and when i stop.
I am having trouble finding the slave cylinder help
Old 03-24-2006, 01:15 AM
AF - Advisor
Follow the hydraulic line from the clutch master, it ends at the slave cylinder. It maybe located in the bell housing. Are you losing fluid?
autozone.com has some free repair guides available. Look at the one for your car. Many of the guides have detailed diagrams and pictures.
Old 03-25-2006, 06:12 AM
C. Cleve C. Cleve is offline
Hi, If you are NOT leaking fluid, Then you have to bleed the hydraulic clutch, Just follow the proceedure in the manual.....Clay..
