Old 07-07-2002, 02:03 PM
stefan525 stefan525 is offline
Send a message via AIM to stefan525
civic front brakes?????
Ok here is my question: If I push my brake pedal all the way down only the right tire locks up and skids, and that makes the car pull to the right. If I don't lock them up it does not pull at all. Is this normal or do I have to bleed my brakes??? Thanks for your help. stefan525
Old 07-08-2002, 04:31 AM
VTiracer VTiracer is offline
Send a message via ICQ to VTiracer
Correct me if I am wrong...please
It could be 3 things...
Design
1) This problem used to go back to the early Honda/Rover designs of 1990+ in the civics and 414's...
The problem is that the brake line to the right wheel is closer to the servo than the left wheel and fluid resistance is less on the right and so power to your right brake piston is stronger than your left one.
2) You could quite possibly have a damaged(weaker) damper on your right side and so constant surface traction is less, making skidding easier
3) You may have a harder compound tyre on the right? (I fear cross-mixed tyre configs!) or a one which is badly or the tracking is out, with less rubber on the road, creating a better chance of skidding?
HTH,
J.
Do I have Oil? What you mean Oil? Of course....ohhh crap..
Front Brake Job - Replace Rotors? buickultra2000 Park Avenue 3 02-09-2010 07:11 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
Another 2004 Alero hub assembly and front brake question. Seattle Al Alero 3 02-20-2009 07:38 AM
