Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 03-21-2006, 04:28 PM
jocro jocro is offline
94 olds will not start
cam sensor checks out ok.....crank sensor checks out ok....comp ok....ignition mod ok.......with key on I get injector pulse and RPM reading codes. The car got progessively worse and finally would not start. Any help greatly appreciated. JOE
Old 03-21-2006, 06:34 PM
maxwedge maxwedge is offline
A990 racer
Re: 94 olds will not start
Good spark on all 6 cylinders and injector pulse, when it won't start? Doe's the scanner read cranking rpms when it won't start? Injector pulse is not present with key on that is 12v only, pulse should occur on cranking.
Old 03-21-2006, 10:10 PM
That is part of my problem........not running..key on I get the pulse reading and the RPM reading......not cranking
Old 03-22-2006, 06:18 AM
A990 racer
You mean a noid lite plugged into an injector connector flashes with just the key on and not cranking the engine?
Old 03-22-2006, 09:53 AM
comp swapped out........still getting false readings on scanner telling me that engine is running..............yes to the noid light and not cranking...His next move is to check wiring harness. JOE
Old 04-16-2006, 09:26 PM
turned out to be crank sensor...............thanks for all the help JOE
